二、ADI ADSP-CM40x参数
100 MHz to 240 MHz ARM Cortex-M4 with floating-point unit
128K Byte to 384K Byte zero-wait-state L1 SRAM with
16K Byte L1 cache
Up to 2M Byte flash memory
16-bit asynchronous external memory interface
Enhanced PWM units
Four 3rd/4th order SINC filters for glueless connection of isolated ADCs
Harmonic analysis engine
10/100 Ethernet MAC
Full Speed USB On-the-Go (OTG)
Two CAN (controller area network) 2.0B interfaces
Three UART ports
Two Serial Peripheral Interface (SPI-compatible) ports
Eight 32-bit general-purpose timers
Four Encoder Interfaces, 2 with frequency division
Single power supply
176-lead (24 mm × 24 mm) RoHS compliant LQFP package
120-lead (14 mm × 14 mm) RoHS compliant LQFP package
