| Parameter | Test Condition | Typ | Unit | |
| Supply Voltage | | 1.8 and 3.3 | V | |
| Total Power Consumption | VHF bands | UHF bands | 0.98 | | W | |
| RF Input Frequency Range | | 42 to 870 | MHz | |
| Noise Figure* | max gain | 4.0 | dB | |
| Wideband IIP3* | N±18,±36; max RF gain | +18 | dBm | |
| Inband IIP3* | N±1,±2; max RF gain | –7 | dBm | |
| LO Phase Noise at 860 MHz | 125 Hz | 250 Hz | 1 kHz | 10 kHz | 100 kHz | –83 | –91 | –96 | –95 | –104 | dBc/Hz | |
| LO Integrated Phase Noise | DSB: 125 Hz to 4 MHz | 0.4 | deg. rms | |
| at 860 MHz | (–43) | (dBc) | | |
| Adjacent Channel Attenuation | N±1; RF input* to DLIF output | 80 | dB | |
| DLIF Output Center Frequency | channel BW = 6 MHz | 7 MHz | 8 MHz | 4 to 7 | MHz | |
| DLIF Differential Output Voltage Swing | programmable | 0.5 to2.0 | Vppd | |
| ALIF Output Center Frequency | channel BW = 6 MHz | 7 MHz | 8 MHz | 4 to 7 | 4.5 to 6.5 | MHz | |
| Analog IF Spurious Distortion | S=P-6 dB | –76 | dBc | |
| ALIF Differential Output Voltage Swing | programmable | 0.5 to 2.0 | Vppd | |
| 欢迎光临 DIY编程器网 (http://diybcq.com/) | Powered by Discuz! X3.2 |
