| http://www.eefocus.com/fpga/329633/file:///C:UsersADMINI~1AppDataLocalTempmsohtmlclip1\01clip_image039.gif x y | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
| 0 | C0 | C1 | C2 | C3 | C4 | C5 | C6 | C7 |
| 1 | C0 | C3 | C6 | -C7 | -C4 | -C1 | -C2 | -C5 |
| 2 | C0 | C5 | -C6 | -C1 | -C4 | C7 | C2 | C3 |
| 3 | C0 | C7 | -C2 | -C5 | C4 | C3 | -C6 | -C1 |
| 4 | C0 | -C7 | -C2 | C5 | C4 | -C3 | -C6 | C1 |
| 5 | C0 | -C5 | -C6 | C1 | -C4 | -C7 | C2 | -C3 |
| 6 | C0 | -C3 | C6 | C7 | -C4 | C1 | -C2 | C5 |
| 7 | C0 | -C1 | C2 | -C3 | C4 | -C5 | C6 | -C7 |
| Logic Utilization | Total Number Slice Registers: 6,364 out of 9,312 68% |
| Number used as Flip Flops: 6,358 | |
| Number used as Latches: 6 | |
| Number of 4 input LUTs: 9,371 out of 9,312 100% (OVERMAPPED) |
| Logic Distribution | Number of Slices containing only related logic: 10,066 out of 10,066 100% |
| Number of Slices containing unrelated logic: 0 out of 10,066 0% | |
| Total Number of 4 input LUTs: 9,696 out of 9,312 104% (OVERMAPPED) | |
| Number used as logic: 8,226 | |
| Number used as a route-thru: 325 | |
| Number used for Dual Port RAMs: 1,008 | |
| Number used as Shift registers: 137 | |
| Number of bonded IOBs: 62 out of 232 26% | |
| IOB Flip Flops: 34 | |
| IOB Master Pads: 1 | |
| IOB Slave Pads: 1 | |
| Number of ODDR2s used: 22 | |
| Number of DDR_ALIGNMENT = NONE 22 | |
| Number of DDR_ALIGNMENT = C0 0 | |
| Number of DDR_ALIGNMENT = C1 0 | |
| Number of RAMB16s: 7 out of 20 35% | |
| Number of BUFGMUXs: 4 out of 24 16% | |
| Number of DCMs: 2 out of 4 50% | |
| Number of MULT18X18SIOs: 20 out of 20 100% |
| 95 | -56 | -111 | 29 | -22 | 115 | 116 | -88 |
| 63 | 102 | -56 | 29 | -126 | -125 | 95 | -56 |
| 37 | 62 | -86 | 101 | -12 | -86 | 15 | -110 |
| 73 | 93 | -110 | 7 | 60 | -8 | 103 | -66 |
| -72 | 5 | -48 | 91 | 15 | -112 | 29 | -18 |
| -14 | 37 | -84 | -8 | 103 | -54 | 25 | 5 |
| -62 | 95 | -60 | -96 | 63 | -22 | 98 | 63 |
| 117 | -88 | 3 | 87 | -56 | 93 | -105 | -126 |
| 260.0000 | -18.2216 | 0.0000 | -1.9048 | 0 | -0.5682 | 0.0000 | -0.1434 |
| -145.7731 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| -15.2385 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| -4.5459 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| -1.1473 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 260 | -17 | 0 | -3 | 0 | 0 | 0 | 0 |
| -145 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| -15 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| -5 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| -2 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| 5.3750 | 9.6394 | 51.7052 | 38.4342 | 47.6250 | 0.741 | -277.2674 | 8.5313 |
| -4.9908 | 113.179 | 29.9029 | 177.4131 | -58.4884 | 270.5674 | -67.2188 | -132.3190 |
| 3.5962 | -51.6039 | 53.3457 | -26.3922 | -27.2503 | -39.9457 | 140.2216 | 28.9813 |
| 18.151 | -105.4604 | -5.125 | 95.4917 | -15.1833 | 48.4768 | -1.8645 | -12.0554 |
| 7.8750 | -32.5188 | -73.2229 | 22.7436 | 28.1250 | 9.7490 | 92.7028 | 15.2282 |
| 85.5709 | -81.2816 | 29.2330 | 184.0511 | -46.2973 | -21.3934 | -14.3454 | -5.8041 |
| -23.0021 | 32.0408 | -113.5284 | 43.7507 | 78.2605 | -4.7500 | 61.6543 | -1.6563 |
| -33.1766 | -29.2447 | -53.8318 | -62.7238 | 10.3477 | 31.7502 | 5.5105 | -33.7774 |
| 6 | 10 | 52 | 38 | 48 | 1 | -277 | 9 |
| -5 | 113 | 30 | 177 | -59 | 271 | -68 | -132 |
| 4 | -52 | 53 | -26 | -27 | -41 | 140 | 29 |
| 19 | -106 | -5 | -95 | -15 | 48 | -2 | -12 |
| 8 | -33 | -73 | 22 | 28 | 10 | 93 | 15 |
| 86 | -82 | 29 | 184 | -46 | -21 | -15 | -5 |
| -23 | 32 | -113 | 43 | 77 | -5 | 62 | -2 |
| -34 | -29 | -53 | -62 | 10 | 32 | 62 | -33 |
| 94 | -56 | -111 | 29 | -22 | 115 | 116 | -88 |
| 63 | 102 | -56 | 29 | -126 | -126 | 95 | -56 |
| -72 | 5 | -48 | 91 | 15 | -112 | 28 | -18 |
| http://www.eefocus.com/fpga/329633/file:///C:UsersADMINI~1AppDataLocalTempmsohtmlclip1\01clip_image063.gif | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
| 良好 | 良好 | 良好 | 良好 | 一般 | 一般 | 一般 | 良好 |
| 好 | 好 | 好 | 好 | 好 | 好 | 好 | 好 |
| 欢迎光临 DIY编程器网 (http://diybcq.com/) | Powered by Discuz! X3.2 |
