标题: 英飞凌LIN网络解决方案 [打印本页]
作者: admin    时间: 2014-10-13 09:05
标题: 英飞凌LIN网络解决方案
LIN, which stands for local interconnect network, is an inexpensive, low-speed (1 to 20 kilobits per second) Class-A, serial multiplexing protocol. It was designed to link switches, actuators and sensors into a sub-bus that connects to the main bus, usually a CAN bus. Vehicle assembly units that could benefit from a LIN sub-bus are door, roof, steering column, seat, climate control, switch panel and intelligent wipers. Furthermore LIN can be used for engine diagnostics. LIN, not designed exclusively for auto applications, also applies to industrial electronics.
Infineon offers LIN transceivers also including bus wake-up functionality as well as microcontrollers with a LIN compliant UART interface.
点击获取相关产品信息
