各OAM协议之间虽然有些内容是重叠的,但是只有相互配合使用才能提供真正意义上端到端的以太网业务管理。在故障管理方面,以太网OAM提供了故障发现、故障确认、故障隔离、故障通告和故障恢复功能。在性能管理方面,以太网OAM支持帧丢失、帧时延、帧时延抖动和业务可用性的度量。
对于故障发现,通过连续性检查消息可以检测到硬件和软件故障。而高频收发的连续性检查消息在大量EVC情况下的扩展性是实际应用中还存在一个问题,MEP和MIP的指配和发现等还需要进一步研究。对于故障确认和故障隔离,可以分别通过环回消息和链路追踪消息来实现。故障通告和告警可以由告警指示消息和远端缺陷指示消息来完成。故障恢复方面,ITU-T专门制定了以太网保护倒换的标准。
城域网具备“电信级”的保证能力是承载网络发展的必然要求,完善OAM功能是部署高质量的、高可靠性的数据网络的关键,各研究团体和标准组织都在积极进行技术研究和标准制定,以期弥补原有以太网在此方面的不足,增强其在连接监视、故障定位、告警指示和性能管理等方面的OAM能力,从而完善其对网络、设备和业务的管理与控制,满足运营商建设可运营、可管理、可盈利网络的要求。 参考文献
1 Zier L, Fischer W, Brockners F. Ethernet-based public communication services: challenge and opportunity.IEEE Communications Magazine,2004,42(3):88-95
2 McFarland M,Salarn S,Checker R.Ethernet OAM: key enabler for carrier class metro ethernet services.IEEE Communication Magazine,2005,43(10):152-157
3 Metro Ethernet Forum Metro Ethernet network architecture frame work-part 1.generic framework.Technical Specification MEF 4,May 2004
4 IEEE 802.1ag.Virtual bridged local area networks-amendment 5: connectivity fault management.Draft 5.2,December 2005
5 IEEE 802.3ah.Amendment: media access control parameters, physical layers, and management parameters for subscriber access network,2004
6 ITU-T Recommendation Y.1730. Requirements for OAM functions in Ethernet based networks,2004
7 ITU-T Draft Rec Y.17ethoam (Y.1731).OAM functions and mechanisms for ethernet based networks,January 2006
8 Metro Ethernet Forum.EMS-NMS information model.Technical Specification MEF 7,October 2004
9 Metro Ethernet Forum.Requirements for management of metro Ethernet phase 1 network elements.Technical Specification MEF 15,November 2005
10 Metro Ethernet Forum.Ethernet local management interface (E-LMI). Technical Specification MEF 16,January 2006
11 Metro Ethernet Forum. Ethernet services attributes phase 1. Technical Specification MEF 10, November 2004
