| pin | Fixed FT2232 pin | description | direction |
| VTG | Voltage target | input | |
| TRST | Reset output | output | |
| TDI | ADBUS1 | JTAG data in to target | output |
| TMS | ADBUS3 | JTAG state machine update | output |
| TCK | ADBUS0 | JTAG clock in to target | output |
| RTCK | ADBUS7 | System return clock | input |
| TDO | ADBUS2 | JTAG data out from target | input |
| TSRST | Bi-directional reset pin | inout | |
| DBGRQ | Debug request | output | |
| DBGACK | Debug acknowledge | input |
| Part | Quantity | Value | Package |
| C1-C7,C13-C21 | 16 | 100nF | C805 |
| C8 | 1 | 3.3uF | SMC_A |
| C9,C10 | 2 | 27pF | C805 |
| C11,C12,C22 | 3 | 4.7uF | SMC_A |
| IC1 | 1 | FT2232H | LQFP64 |
| IC2 | 1 | 93LC46B | SOIC8 |
| IC3 | 1 | LD1117-3.3 | SOT223 |
| IC9 | 1 | XC2C32A_VQ44_2 | VQ44 |
| JP1-4 | 1 | 0.1" pin header | 1X0X |
| JTAG | 1 | 2x10 shrouded header (0.1”) | PINHEAD_-_COPY_PINSHRD_PTH_2X10 |
| L1,L2 | 2 | ferrite bead (800mA+) | FB805 |
| PWR | 1 | LED | CHIPLED_0805 |
| R1 | 1 | 12K 1% | R805 |
| R2 | 1 | 1K | R805 |
| R3,R4,R5 | 3 | 10K | R805 |
| R6 | 1 | 2.2K | R805 |
| R10 | 1 | 1K | R805 |
| USB | 1 | USB mini-B connector | CONN_USB_MINI-B |
| X1 | 1 | 12MHz crystal | 4X6 |
| 欢迎光临 DIY编程器网 (http://diybcq.com/) | Powered by Discuz! X3.2 |
