| Frequency Band | 2500-2700 MHz |
| Type of Antenna | PCB with dual-polarization (±45 degree) & two feeds, |
| Smart Tile Size | <180 x 105x 59 mm |
| Physical Dimensions | <100 x 100 x 22 mm |
| Peak Gain | >5 dBi |
| Feed Impedance | 50 |
| VSWR of antenna ports | < 2 |
| Isolation between ports | > 15 dB |
| 3dB Beamwidth | > 60 degree |
| Co-cross polarization ratio | > 13 dB |
| Front to Back Ratio | > 13 dB |
| Max Power | < 1W |
| VSWR on coupling port 1 or 2 | < 2 |
| Coupling level from antenna port 1( or port 2) to corresponding coupling port 1 (or port 2) | -23.8 dB±1 dB @ 2600 MHz |
