The extra diode raises the output voltage of the 78L12 by 0.6 volt, ensuring that it is within the 12.0-to-14.0-volt range specified for the PIC.
Cheap assorted transistors often do not have the pins in the specified arrangement; all the transistors in an assortment will not necessarily be the same. Only transistors with type numbers printed on them are trustworthy.
| 欢迎光临 DIY编程器网 (http://diybcq.com/) | Powered by Discuz! X3.2 |
