标题: HV Rescue Shield 2 [打印本页]
作者: liyf    时间: 2011-11-26 09:21
HV Rescue Shield 2Introducing the AVR HV Rescue Shield 2
The HV Rescue Shield 2 is a high voltage parallel mode fuse programmer for Atmel AVR microcontrollers.
It currently supports a wide variety of AVR chips, including the 28-pin ATmega48/88/168/328 series, the 20-pin ATtiny2313, and many 8-pin ATtiny devices (such as the ATtiny25/45/85 and ATtiny13A).  A list of supported devices is in progress, but the Rescue Shield supports many more devices than those listed on the wiki.
Update Feb 2011: Version 2.1 is in stock and shipping now!
Features:New in release 2.0:Requirements:What you get:What the HV Rescue Shield is not:The HV Rescue Shield is not a general purpose AVR microcontroller programmer.  That is,  it can’t be used to perform a chip erase or program flash memory.  It is intended only for programming the AVR’s configuration fuses: HFUSE, LFUSE, and EFUSE (where applicable).
The hardware implements all of the control lines to support flash programming, but the code just isn’t there.  If anyone would like to volunteer to rewrite the code to support more features, such as general flash programming, please post in the support forum!
The HV Rescue Shield is 100% open source (hardware and software).  OSHW rules!
Kits!Here is a snapshot of the components included with the kit.
Schematic (PNG format, click for larger version):
Layout (PNG format):
