9: bL InitStack ;初始化堆栈 Initialize the stack
bL TargetResetIni;目标板基本初始化 ;跳转到c语言入口 Jump to the entry point of C program
b __main
周立功启动代码:
;/****************************************Copyright (c)**************************************************
;** Guangzou ZLG-MCU Development Co.,LTD.
;** graduate school
;** http://www.zlgmcu.com
;**--------------File Info-------------------------------------------------------------------------------
;** File name: Startup.s
;** Last modified Date: 2004-09-17
;** Last Version: 1.0
;** Descriptions: The start up codes for LPC2100, including the initializing codes for the entry point of exceptions and the stacks of user tasks.
;** Every project should have a independent copy of this file for related modifications
;** Created by: Chenmingji
;** Created date: 2004-02-02
;** Version: 1.0
;** Descriptions: The original version//原著
;** Modified by: Chenmingji
;** Modified date: 2004-09-17
;** Version: 1.01
;** Descriptions: Modified the bus setting to adapt for many common situations
;** //改进了总线,可以根据这里的更改来控制总线的速率
;** Version: 1.02
;** Descriptions: Added codes to support the enciphering of the chip
;** //增加了芯片加密
;** Version: 1.04
;** Descriptions: Renewed the template, added codes to support more compilers
;** //重建模板,加入更多代码来支持更多的编译
;** Modified by:
;** Modified date:
;** Version:
;** Descriptions:
bCFG_16DEF EQU 0x10000400 ;// 16bit bus
bCFG_CS3 EQU (bCFG_16DEF | (0x01= 0x1fc
INFO 1," The data at 0x000001fc must be 0x87654321. Please delete some source before this line."
ENDIF
CrpData
WHILE . < 0x1fc
NOP
WEND
CrpData1
DCD 0x87654321 ;/*When the Data is 为0x87654321,user code be protected. 当此数为0x87654321时,用户程序被保护 */
ENDIF
;/* 分配堆栈空间 */
AREA MyStacks, DATA, NOINIT, ALIGN=2
SvcStackSpace SPACE SVC_STACK_LEGTH * 4 ;Stack spaces for Administration Mode 管理模式堆栈空间
IrqStackSpace SPACE IRQ_STACK_LEGTH * 4 ;Stack spaces for Interrupt ReQuest Mode 中断模式堆栈空间
FiqStackSpace SPACE FIQ_STACK_LEGTH * 4 ;Stack spaces for Fast Interrupt reQuest Mode 快速中断模式堆栈空间
AbtStackSpace SPACE AbT_STACK_LEGTH * 4 ;Stack spaces for Suspend Mode 中止义模式堆栈空间
UndtStackSpace SPACE UND_STACK_LEGTH * 4 ;Stack spaces for Undefined Mode 未定义模式堆栈
AREA Heap, DATA, NOINIT
bottom_of_heap SPACE 1
AREA Stacks, DATA, NOINIT
StackUsr
END
;** End Of File
