标题: PIC 滚动码的解码程序 [打印本页]
作者: liyf    时间: 2012-1-27 14:12
标题: PIC 滚动码的解码程序
                    ???? 摘要:PIC单片机滚动码的解码程序
  #include
  global DECRYPT
  global KEY0,KEY1,KEY2,KEY3,KEY4,KEY5,KEY6,KEY7
  global CSR0,CSR1,CSR2,CSR3,CSR4,CSR5,CSR6,CSR7,CSR8
  #define? HOP1 CSR0??? ; ﹚竡 HOP1"4 单 CSR1"4
  #define? HOP2 CSR1
  #define? HOP3 CSR2
  #define? HOP4 CSR3
  #define? MAX_CODE_LENGTH .72
  #define? CODE_LENGTH .66
  UDATA_SHR???? ; Difine CSR0:CSR7 ON Share memory
  CSR0? res 1????? ; Hopping Code 钡Μ纗既竟 (LSB)
  CSR1? res 1
  CSR2? res 1
  CSR3? res 1
  CSR4? res 1
  CSR5? res 1
  CSR6? res 1
  CSR7? res 1
  CSR8? res 1????? ; Hopping Code 钡Μ纗既竟 (MSB)
  Encrypt_Data UDATA 0x20
  KEY0? res 1????? ; 64-bit 秆盞じン戈 (LSB)
  KEY1? res 1
  KEY2? res 1
  KEY3? res 1
  KEY4? res 1
  KEY5? res 1
  KEY6? res 1
  KEY7? res 1
  UDATA
  CNT0? res 1
  CNT1? res 1
  HOP_LENGTH res 1
  MASK? res 1
  KEELOQ_temp res 1
  KEELOQ_CODE CODE
  ;**** Rotate CSRs regiSTer right 1 bit
  ROT_CSRs
  RRF? CSR8,F
  RRF???? CSR7,F
  RRF???? CSR6,F
  RRF???? CSR5,F
  RRF???? CSR4,F
  RRF???? CSR3,F
  RRF???? CSR2,F
  RRF???? CSR1,F
  RRF???? CSR0,F
  return
  ; FUNCTION????? : DECRYPT ()
  ; DESCRIPTION?? : DECRYPTS 32 BIT [HOP1:HOP4] USING [CSR0:CSR7]
  DECRYPT
  BANKSEL CNT1
  MOVLW?? (.11+1)???????? ; OUTER LOOP 11+1 TIMES
  MOVWF?? CNT1?????????? ; OUTER LOOP 11+1 TIMES
  DECRYPT_OUTER
  MOVLW?? .48???????????? ; INNER LOOP 48 TIMES
  MOVWF?? CNT0?????????? ; INNER LOOP 48 TIMES
  DECRYPT_INNER
  CLRWDT???? ; RESET WATCHDOG TIMER
  MOVFW?? CNT1?? ; LAST 48 LOOPS RESTORE THE KEY
  XORLW?? .1????????????? ; LAST 48 LOOPS RESTORE THE KEY
  btfsc STATUS,Z??????? ; LAST 48 LOOPS RESTORE THE KEY
  GOTO??? ROTATE_KEY????? ; LAST 48 LOOPS RESTORE THE KEY
  ; THE LOOKUP TABLE IS COMPRESSED INTO IN 4 BYTES TO SAVE SPACE
  ; USE THE 3 LOW INDEX BITS TO MAKE UP AN 8-BIT BIT MASK
  ; USE THE 2 HIGH INDEX BITS TO LOOK UP THE VALUE IN THE TABLE
  ; USE THE BIT MASK TO ISOLATE THE CORRECT BIT IN THE BYTE
  ; PART OF THE REASON FOR THIS SCHEME IS BECAUSE NORMAL TABLE
  ; LOOKUP REQUIRES AN ADDITIONAL STACK LEVEL
  bcf STATUS,C???????? ; CLEAR CARRY (FOR THE LEFT SHIFT)
  MOVLW?? .1????????????? ; INITIALISE MASK = 1
  BTFSC?? HOP3,3??????? ; SHIFT MASK 4X IF BIT 2 SET
  MOVLW?? B'00010000'???? ; SHIFT MASK 4X IF BIT 2 SET
  MOVWF?? MASK??????????? ; INITIALISE MASK = 1
  BTFSS?? HOP2,0??????? ; SHIFT MASK ANOTHER 2X IF BIT 1 SET
  GOTO??? $+3
  RLF???? MASK,F
  RLF???? MASK,F
  BTFSC?? HOP1,0??????? ; SHIFT MASK ANOTHER 1X IF BIT 0 SET
  RLF???? MASK,F
  ; MASK HAS NOW BEEN SHIFTED 0-7 TIMES ACCORDING TO BITS 2:1:0
  MOVlw HIGH TABLE
  MOVwf PCLATH
  MOVlw LOW TABLE
  MOVwf KEELOQ_Temp
  MOVLW?? 0?????????????? ; TABLE INDEX = 0
  BTFSC?? HOP4,1
  IORLW?? .2????????????? ; IF BIT 3 SET ADD 2 TO THE TABLE INDEX
  BTFSC?? HOP4,6
  IORLW?? .4????????????? ; IF BIT 4 SET ADD 4 TO THE TABLE INDEX
  addwf KEELOQ_Temp,W
  btfsc STATUS,C
  incf PCLATH,F
  MOVwf PCL??????????? ; ADD THE INDEX TO THE PROGRAM COUNTER
  ;? [ MUST BE IN LOWER HALF OF PAGE ]
  TABLE
  MOVLW?? 0x2E??????????? ; BITS 4:3 WERE 00
  GOTO??? TABLE_END?????? ; END OF LOOKUP
  MOVLW?? 0x74??????????? ; BITS 4:3 WERE 01
  MOVLW?? 0x5C??????????? ; BITS 4:3 WERE 10
  MOVLW?? 0x3A??????????? ; BITS 4:3 WERE 11
  TABLE_END
  ANDWF?? MASK,1????????? ; ISOLATE THE CORRECT BIT
  MOVLW?? 0?????????????? ; COPY THE BIT TO BIT 7
  btfss STATUS,Z??????? ; COPY THE BIT TO BIT 7
  MOVLW?? B'10000000'???? ; COPY THE BIT TO BIT 7
  XORWF?? HOP2,W????? ; ONLY INTERESTED IN BIT HOP2,7
  XORWF?? HOP4,W????? ; ONLY INTERESTED IN BIT HOP4,7
  XORWF?? KEY1,W?? ; ONLY INTERESTED IN BIT KEYREG1,7
  MOVWF?? MASK??????????? ; STORE W TEMPORARILY (WE NEED BIT 7)
  RLF???? MASK,F????????? ; LEFT ROTATE MASK TO GET BIT 7 INTO CARRY
  RLF???? HOP1,F????????? ; SHIFT IN THE NEW BIT
  RLF???? HOP2,F
  RLF???? HOP3,F
  RLF???? HOP4,F
  ROTATE_KEY
  bcf STATUS,C?? ; CLEAR CARRY
  BTFSC?? KEY7,7??????? ; SET CARRY IF LEFTMOST BIT SET
  bsf STATUS,C???????? ; SET CARRY IF LEFTMOST BIT SET
  RLF???? KEY0,F????????? ; LEFT-ROTATE THE 64-BIT KEY
  RLF???? KEY1,F
  RLF???? KEY2,F
  RLF???? KEY3,F
  RLF???? KEY4,F
  RLF???? KEY5,F
  RLF???? KEY6,F
  RLF???? KEY7,F
  DECFSZ? CNT0,F????????? ; INNER LOOP 48 TIMES
  GOTO??? DECRYPT_INNER?? ; INNER LOOP 48 TIMES
  DECFSZ? CNT1,F????????? ; OUTER LOOP 12 TIMES (11+1 TO RESTORE KEY)
  GOTO??? DECRYPT_OUTER?? ; OUTER LOOP 12 TIMES (11+1 TO RESTORE KEY)
  RETLW?? 0?????????????? ; RETURN
