串行通信UART及PROTEUS仿真设计
2011-4-28 22:35
C51跟atmega64的串行通信。相关理论知识这里就不多说,只提几个:
51的UART所用的几个寄存器
SCON:SM0 SM1 SM2 REN RB8 TX8 RI TI
PCON: SMOD -- -- -- --- ---PD IDLE
T2CON: TF2 EXF2 RCLK TCLK EXEN2 TR2 C/_T CP/_RL2
TH2,TL2
波特率为9600bps
avr:atmega64的USART的两个
所用到的寄存器
这里用的是uart0,所以初始化时应该设置相关的寄存器有:
UCSR0A: RXC TXC UDRE FE DOR UPE U2X MPCM
UCSR0C :-- UMSEL UPM1 UPM0 USBS UCSZ1 UCSZ0 UCPOL
UBRR0H、UBRR0L、
UCSR0B :RXCIE TXCIE UDRIE RXEN TXEN UCSZ2 RXB8 TXB8
别问我这些都是代表什么含义,不懂自己翻书去。。
proteus仿真如下图:
仿真结果如下图所示:
其中要注意的是:
因为我在仿真中只能选择atmega64的CKSEL Fuse中的8MHz,所以在AVR的程序中初始化波特率是按8MHz来计算的。所以仿真归仿真,注意实际中应用。
51单片机用定时器1来产生波特率时,看书据说模式2下,12MHz时最高只能到达4800bps。这里就只好用定时器2来。不过也挺好用的。。仿真时用的是8052核。。否则没反应不要怪我哦。。
最后把程序附上,里面有些变量声明了没有用到,当初只是实验。。
51的:
#include "reg52.h"
#define AA 0x61
#define commun_symbol 0x31
sbit LED=P2^0;
unsigned char Tx[]={"my name is seven!"};
void uart_init(void)
SCON = 0x50;
RCAP2H = 0xFF;
RCAP2L = 0xD9;
TH2 = 0xFF;
TL2 = 0xD9;
T2CON = 0x34;
void uart_send(unsigned char byData)
TI=0;
SBUF=byData;
while(TI==0);
TI=1;
unsigned char uart_receive(void)
RI=0;
while(RI==0);
RI=1;
return(SBUF);
void main()
unsigned char byBuff,i;
uart_init();
uart_send(commun_symbol);
while(1)
byBuff=uart_receive();
LED=1;
if(byBuff==0x31)
for(i=0;i
void uart0_init(void)
UCSR0B = 0x00; //disable while setting baud rate
UCSR0A = 0x00;
UCSR0C = 0x06;
UBRR0L = 0x33; //set baud rate lo
UBRR0H = 0x00; //set baud rate hi
UCSR0B = 0x18;
void uart0_Transmit( unsigned char data )
/* Wait for empty transmit buffer */
while ( !( UCSR0A & (1ta & 0x0100 )
//UCSR0B |= (1ta into buffer, sends the data */
UDR0 = data;
unsigned char uart0_Receive( void )
/* 等待接收数据*/
while ( !(UCSR0A & (1
#include "spi.h"
//-----------send a commun_symbol-----
//-----------receive a commun_symbol--
// receive the data and send
void main()
unsigned char bybuff;
DDRB=0xff;
PORTB=0xff;
uart0_init();
do
bybuff=uart0_Receive();
while (bybuff!=commun_symbol);//commun_symbol);
while(1)
uart0_Transmit(bybuff);
PORTB=(0xff|bybuff);
ok,任务完成了,改天实验一下!
