标题: 用现成品改装的烤箱回流焊 [打印本页]
作者: liyf 时间: 2012-10-6 11:32
标题: 用现成品改装的烤箱回流焊
http://www.instructables.com/id/ ... ard/?ALLSTEPS#step4
Step 4Build a Reflow Oven & Controller
You may have noticed a trend here toward automation, and I don't deny it. This whole project was an attempt at small scale mass production. So here we go: instead of hand soldering every board, hey, guess what- I can just stencil on solder paste, glob it on real good sorta, and stuff the whole thing in a toaster for a minute or two?
Yup, that's the general idea.
Surface Mount Technology
_______________________________________________________________________
The part that makes this possible is choosing Surface Mount components over conventional through-hole components. They are significantly smaller and less expensive, there are no holes to drill, and board size is reduced. Any disadvantages they have are just side effects of their advantages; they can easily be too small to manipulate without the proper tools.
Typical SMT fabrication works like this: solder paste is spread through a stencil unto the solder pads of the board. Then the components are stuck into the paste, and the entire thing is ramped at a set rate to several set temperature points, depending on the solder and heat resistance of the components. In our case, every component except two can be baked; the battery and the switch will need to be hand soldered later.
Regardless, the higher entry cost is outweighed by the long term advantages, so it's time to build a temperature controlled reflow oven so we don't need to get carpal tunnel soldering hundreds of little grains of sand.
The Controller
The cheapest commercially available reflow oven is certainly several thousand dollars. On the other end of the spectrum, the cheapest stand alone controllers are in the $100 range. Since the expensive ones are too expensive, and the cheap ones are too crippled, I had to build my own.
All the controller has to do is monitor the temperature of the oven and change it when it need to be changed. The ideal way to do this is with a Ramp/Soak temperature controller, used in factory automation for just such a purpose. I was lucky enough to get a Watlow SD6R-LCJE-AARG ramp./soak controller for less than 50 dollars, and I built the whole thing around it. You should be able to find something similar in the same price range without too much trouble. Just make sure it can ramp the temperature to multiple setpoints, as opposed to simply maintaining one stable temperature.
The Walow is pretty forgiving; it will take 24 AC/DC as power input it can display temperature in Fahrenheit or Celsius, and it accepts almost any type of thermocouple. More importantly, it has low voltage DC as a control output that we will use to drive a solid state relay, which will in turn switch on and off the heaters of a standard toaster oven.
The Toaster Oven
Any toaster oven will work, though the smaller the better, as the smaller volume of air will mean it can heat up much faster. Try and look for a newer oven with quartz heaters, but ceramic heaters would also be suitable. If your oven has a setting for always on operation, such as bake, you'll be fine. Otherwise, you will need to open it up and wire the heaters to always be on - a dangerous affair that I would not recommend.
You'll also need a thermocouple with a heat-resistant insulation, as our oven will reach temperatures of 260º C. This presents yet another fire hazard, so don't leave it unattended, keep it away from the walls, and don't set anything on it (unless it has heat resistant plastic feet!). The last thing to do is simply to drill a hole in the back of the over large enough for the thermocouple to fit through. There is no need to worry too much about heat loss with our oven, but the hole shouldn't be too much larger than the thermocouple. On the other hand, too small a hole and the fiberglass insulation on the wire will begin to fray from repositioning it. The hole should be placed slightly above where the center rack in the oven would be, so that the thermocouple can just touch the surface of the circuit board.
References
Parts
- Toaster oven, preferably small volume, with four quartz heating elements
- Metal project enclosure
- Ramp/Soak Temperature Controller, here's one option, but you should try eBay first
- 10A or greater Solid State Relay, Crydom d2410f
- High temp thermocouple K-Type, 270 to +1372º C (-454 to +2501º F)
- heat resistant rubber or plastic feet & hardware
- indicator lamp, panel mount 120V
- electrical socket, panel mount
- two wire screw down terminals, panel mount
Tools & Supplies
- Power Drill
- Dremel or other rotary tool, with cutoff wheel
- Crimping tool
- Soldering iron, solder
- mounting hardware
- various crimp on connectors sized for your parts
- several feet of 14-16 gauge wire, various colors
- Thermal heatsink paste
Reflow Controller wiring diagram.svg16 KB
Reflow Controller wiring diagram.zip3 KB
作者: jobo007 时间: 2012-10-17 09:25
难道这就是传说中的沙发?楼主思路非常妙啊,顶一个!!!!
作者: zyh555 时间: 2012-10-17 23:24
果然是高手出自民间!
作者: 無結局的等待 时间: 2013-6-17 22:43
学习学习啊
作者: dwl65 时间: 2014-10-28 21:41
这个也可以做回流机,佩服。
作者: robter 时间: 2015-10-15 22:10
这个很好,感谢楼主的好资料
作者: gl542400 时间: 2017-2-11 15:17
好精点的压缩包图标!
Powered by Discuz! X3.2 |
