标题: SMT Reflow (Toaster) Oven [打印本页]
作者: liyf 时间: 2012-10-6 14:18
SMT Reflow (Toaster) Oven - IntroductionFigure 1: A Hobbyist Reflow Toaster Oven Comprises Of A Compact Oven and PID Controller. The aim of converting a toaster oven (1), (2) into a SMT reflow oven is to provide a temperature controlled enclosure to enable hobbyists design engineers to assemble Printed Circuit Boards (PCBs) containing Surface Mount Devices (SMDs). In this case, a 230V, 50Hz 600W 6L signature toaster oven has been used.
Figure 2 : A Typical Solder Reflow Profile. A solder reflow temperature profile, is used to control the process by using a Proportional Integral Derivative (PID) controller. The PID ensures that the soldering process goes through a gradual preheating stage and a brief duration of soldering temperature followed by a cooling stage. The cooling stage is typically performed manually by partially opening the toaster oven door! [Taken from the Application Note AN081 - Reflow soldering Guidelines for Surface-Mount Devices, June 2002 Ver 4, Altera Corp].
Figure 3 : A Typical Conversion Includes Some Of The Components Shown In The Figure. (1) A Solid State Relay (SSR) is used to control the on/off switching of the heating elements and hence control the heat profile of the oven. (2) A replacement front panel is typically need to mount any "added" instrumentation. In this case acrylic has been temporarily used. (3) A commercial PID controller is used to produce the soldering temperature profile. (4) A thermocouple is the sensor used to monitor the instantaneous temperature of the toaster oven. (5) Insulation of the instrumentation compartment, is required to ensure that the instruments are operated within their operating temperatures. In this case two layers of soldering mat has been used.
Figure 1: Major Components: This figure shows the major components required to convert a compact oven into a SMT reflow oven. (1) Well, you need a compact oven (aka toaster oven, electric oven etc). The capacity of the oven required could depend on the size of PCB's that you anticipate assembling. For this project I choose to use one of the smallest sizes - a 6 litre one. (2) PID controllers as you can imagine come in a variety of types and sizes.
The one used in this project is an Universal Digital PID Programmable Temperature Controller that is sold with a "free" 0 - 400C K-type thermocouple. (3)Terminal assortments are extremely useful especially when you consider the health and safety message in Figure 1. (4) Soldering mats are used to provide thermal insulation for the instrumentation compartment. Other types of insulators could be used too.
(5) Solid State Relays (SSRs) are characterised by the maximum amount of current that can flow through them. For this project I decided to be on the safe side and use a 40A one. This could be considered to be an over kill but health and safety took precedence when I chose this part! (6) RTV heat resistant silicone sealant and adhesive.
Figure 2: Major Components Costs : The pie chart above shows the cost (16-Feb-2010) of the major components used in the project when purchased from our favourite online store (.co.uk) The darker shade of the same colour shows the average postage and packaging cost for an item shaded in the lighter colour.
The darker shade suggests that if you live close to a hardware store it could be beneficial to pay it a visit as quite a considerable percentage of the total project cost could be saved on postage and packaging alone. You could also attempt to purchase the items second hand if possible especially the toaster oven as the conversion process will almost definitely invalidate its warranty.
Figure 3: Compact\Mini\Toaster Oven : The compact oven used was one from Signature that has a rating of AC 230V, 50Hz and 600W (1) with a capacity of 6 litres. It turned out to be quite a good oven to use for this project as it was fairly straight forward to disassemble.
The triangle head tamper proof security screw (2) should provide no opposition for a trained and qualified electrician! This oven has two heating elements (3) one at the top and one at the bottom. The top control knob (4) is to turn the top, bottom or both heating elements on or the appliance off. The other control knob (5) is a timer that allows the oven to be turned on for up to a maximum of 15 minutes.
For this particular application I decide to remove the front panel that hosts the knobs completely. If I hadn't have done this it would have meant cutting through the metal panel to mount the PID controller. In some SMT toaster oven conversions, described on other websites, the timer and upper control knob are used as part of the final control circuitry. However, in this case I decided to rely on the PID controller for all control (see below).
Figure 4: A Tale of Two Compartments : A toaster oven typically consists of two compartments. One for baking sausage rolls or PCB's with SMD devices (1) and another that could be considered to be the component or instrumentation compartment (2).
The aim of the toaster oven to SMT reflow oven conversion project is to replace or augment the basic analog control circuitry with a sophisticated embedded computer system to control the reflow solder process.
The instrumentation compartment, of the signature oven, has convenient mounting points (3) (which were used to secure the SSR mounting bracket - see below). The heating elements in this unit used a convenient screw and nut feature (4) for securing terminal leads and did not employ a more sophisticated tamper proof securing method. This was quite convenient as the latter offer more resistance to change even for the trained electrician!
Figure 5: Solid State Relay and Mounting Bracket: A bracket to mount the SSR relay was cut from aluminium sheet metal (1). The bracket (5) is used to mount and conduct heat away from the SSR. The SSR could be considered to consist of a control part (4) that accepts, in this case, a 3 - 32VDC voltage and a switching part (3) used to switch the heating elements in the oven on and off. Terminal connectors (2) are used to connect the switching part of the SSR to the heating elements. The switching part of the SSR can accept voltages of between 24 and 380VAC.
Figure 6: Insulating the Instrumentation Compartment:The instrument compartment should be insulated to ensure that any instrumentation placed within the compartment operates within an environment that is tolerable, temperature wise. The compartment is insulated by using soldering mats which can typically resist the high temperatures attained during the SMT reflow process. The mats that I bought can resist temperatures of up to 600C.
Annoyingly though, one mat at 300mm by 240mm was just too small to fold in half to create the two layers of insulation required, so I had to use two mats cut to shape. Dabs of RTV silicone adhesive (1) were used to secure the mats (2) in place. The SSR mounting bracket (3a) was tethered in place using M3 screws and nuts (3c).
The mounting bracket ended up being in a convenient location as it is coincident with the air flow provided by the air vents (3d). RTV silicone sealant was also placed around the electrical contact (3b) of each heating element to insulate the contact from any electrical conductivity associated with the soldering mat.
Figure 7: Completing the Story: A K-type thermocouple (1) rated at 400 degrees Celcius was included for free with the PID controller (3). The PID controller has been connected to the thermocouple and temporarily mounted on an acrylic sheet (6) cut into the shape of the front panel. A hole has been drilled into the side of the instrumentation compartment and the thermocouple has been passed though to the heating chamber (4). The SSR (2) is mounted on the aluminium bracket to complete the construction of the instrumentation compartment.
Figure 8:SSR Terminal Configuration: After the cover to the instrumentation compartment was fitted back into place, the toaster oven was turned on. To my surprise a negative temperature was reported on the front panel of the PID controller (3). After going over the problem for a while, well a few hours actually, I decided to revisit the connection of the thermocouple to the PID controller.
Initially the thermocouple was connected to the SSR as in (1) which produced the negative reading. I then decided to swap the thermocouple leads around (2) such that the +ve terminal of the PID controller connects to the -ve thermocouple lead and vice versa which solved the mystery, although I am still baffled about what thermocouple colour codes actually mean!
Figure 9: Result!:The now working SMT reflow oven appears to give excellent results and the PID controllers seems to be remarkably accurate.
This article, is part of a set of articles, that demonstrates the conversion of a compact electric oven, popularly known as a toaster oven, into a surface mount technology (SMT) reflow oven. In this article the measurement of the temperature ramp rate, of the toaster oven, is undertaken. The measurements, which are done upto a temperature of up to 250 degrees Celcius, are performed to help characterise the oven under different combinations of loading and insulation.
Figure 1 : Compact Oven Parts: A compact or mini toaster oven consists of quite a few parts that can impact on the temperature ramp rate these are (1) the grill rack, (2) the glass door, (3) the baking tray and (4) the heating elements.
The temperature ramp rate of the toaster oven converted for use in the SMT reflow process (Figure 2) could be critical to the success of the project as too high or too low a temperature ramp rate could mean that the solder will not reflow correctly. A consequence of soldering devices with an inappropriate soldering reflow profile could mean that the soldered components could exhibit erratic results due to internally cracked solder joints or other soldering anomalies.
Figure 2 : Temperature Ramp Rate: Depending on the sources you read and the type of solder used, the temperature ramp rate of the soldering temperature profile could be between 0.5 and 3.0 degrees Celcius per second.
The temperature ramp rate has been measured crudely under different loading and insulating conditions by noting the measured temperature of the PID controller every 5 seconds when the set temperature is 230 degrees Celcius. The PID controller has been set to act in P mode only (I = D = 0). The loading and insulating conditions are as follows:
- Baking Tray : Only the baking tray has been placed in the oven and the glass door has been left uninsulated.
- Aluminium Sheet and Baking Tray : An aluminium sheet, that covers approximately 85% of the glass door, has been placed inside the toaster oven and in front of the glass door to act as insulation. The baking tray was placed in the oven.
- Aluminium Sheet, Baking Tray and Soldering Mat : An aluminium sheet, that covers approximately 85% of the glass door, has been placed inside the toaster oven in front of the glass door. The baking tray has been placed in the oven. In addition a single layer of soldering mat has been placed on top of the toaster oven to prevent heat loss from the top of the toaster oven.
- Tin Foil and Baking Tray : Tin foil has been used to cover the glass door to act as insulation. A baking tray has been placed in the oven.
- Tin foil and Grill Rack : Tin foil has been used to cover the glass door to act as insulation. A grill rack has been placed in the oven.
- Grill Rack : Only the grill rack has been placed in the toaster oven and the glass door has been left uninsulated.
Figure 3 : Measurement Results: The result of insulating and loading the toaster oven under different conditions. The best temperature ramp rate result has been achieved (~1 degree Celcius/s) when the glass door has been insulated and the baking tray is left in the oven. The worst result is achieved (<0.5 degrees Celcius/s) when the glass door is not insulated and the baking grill is left in the oven.
I intend to analyse the results more comprehensively in the characterisation article of the SMT reflow oven series however, it is safe to say that the results suggest that too much heat is being lost through the uninsulated glass door. The temperature ramp rate tends to be higher too when the baking tray is left inside the toaster oven compared to when the grill rack is left in the oven.
Figure 4 : Insulation Material : (1) Reflect-a-gold is considered to be the Rolls Royce of insulation material and almost has a price tag to match! It is described as " .... state-of-the-art polymer laminated glass cloth is extremely light weight and capable of handling continual operating temperatures up to 850º F, reflecting 80% of all radiant heat while offering a weight savings advantage versus other types of reflective materials". (2) Aluminium tape is commonly available and much cheaper to buy and it should also provide adequate insulation for the SMT reflow oven project although not as efficiently as the reflect-a-gold material.
作者: robter 时间: 2015-10-26 21:40
这个很好,学习了,多谢楼主
Powered by Discuz! X3.2 |
