| 84 Pin PLCC Socket | Signal Name | DIP40 of the ALL03 / ALL07 | Comments |
| 1 | GND | 20 |
| 2 | VCC | 9 |
| 3 | 10K Pulldown R | - |
| 4 | 10K Pulldown R | - |
| 5 | 10K Pulldown R | - |
| 6 | 10K Pulldown R | - |
| 7 | 10K Pulldown R | - |
| 8 | 10K Pulldown R | - |
| 9 | 10K Pulldown R | - |
| 10 | SI/O7 | 25 |
| 11 | GND | 20 |
| 12 | SI/O8 | 26 |
| 13 | 10K Pulldown R | - |
| 14 | 10K Pulldown R | - |
| 15 | 10K Pulldown R | - |
| 16 | 10K Pulldown R | - |
| 17 | 10K Pulldown R | - |
| 18 | 10K Pulldown R | - |
| 19 | SI/O15 | 1 |
| 20 | CLK1 | pin 4 IC 74LS14 |
| 21 | VCC | 9 |
| 22 | GND | 20 |
| 23 | VPP | center pin SW1-2 | if MACH1 shorted to 13 if MACH435 shorted to 37 |
| 24 | SI/O16 | 2 |
| 25 | SI/O17 | 5 |
| 26 | 10K Pulldown R | - |
| 27 | 10K Pulldown R | - |
| 28 | 10K Pulldown R | - |
| 29 | 10K Pulldown R | - |
| 30 | 10K Pulldown R | - |
| 31 | SI/O23 | 27 |
| 32 | GND | 20 |
| 33 | SI/O24 | 28(corrected) |
| 34 | SI/O25 | 24(corrected) |
| 35 | 10K Pulldown R | - |
| 36 | 10K Pulldown R | - |
| 37 | 10K Pulldown R | - |
| 38 | SEC | 19 |
| 39 | 10K Pulldown R | - |
| 40 | 10K Pulldown R | - |
| 41 | ENABLE | center pin Switch SW1-1 | if MACH1 shorted to 37 if MACH435 shorted to 13 |
| 42 | VCC | 9 |
| 43 | GND | 20 |
| 44 | VCC | 9 |
| 45 | 10K Pulldown R | - |
| 46 | 10K Pulldown R | - |
| 47 | 10K Pulldown R | - |
| 48 | 10K Pulldown R | - |
| 49 | 10K Pulldown R | - |
| 50 | 10K Pulldown R | - |
| 51 | 10K Pulldown R | - |
| 52 | SI/O39 | 29 |
| 53 | GND | 20 |
| 54 | SI/O40 | 30 |
| 55 | 10K Pulldown R | - |
| 56 | 10K Pulldown R | - |
| 57 | 10K Pulldown R | - |
| 58 | 10K Pulldown R | - |
| 59 | 10K Pulldown R | - |
| 60 | 10K Pulldown R | - |
| 61 | SI/O47 | 3 |
| 62 | CLK2 | 34 |
| 63 | VCC | 9 |
| 64 | GND | 20 |
| 65 | MD1 | 17 |
| 66 | SI/O48 | 4 |
| 67 | 10K Pulldown R | - |
| 68 | 10K Pulldown R | - |
| 69 | 10K Pulldown R | - |
| 70 | 10K Pulldown R | - |
| 71 | 10K Pulldown R | - |
| 72 | 10K Pulldown R | - |
| 73 | SI/O55 | 31 |
| 74 | GND | 20 |
| 75 | SI/O56 | 32 |
| 76 | 10K Pulldown R | - |
| 77 | 10K Pulldown R | - |
| 78 | 10K Pulldown R | - |
| 79 | 10K Pulldown R | - |
| 80 | 10K Pulldown R | - |
| 81 | 10K Pulldown R | - |
| 82 | 10K Pulldown R | - |
| 83 | MD2 | 18 |
| 84 | VCC | 9 |
| 10nF cap. between |
 | pin 13 and pin 20 |
| pin 1 IC 74LS14 |
 | 33 |
| pin 2,3 IC 74LS14 shorted together |
| pin 4 IC 74LS14 | 20 |  |
| pin 7 IC 74LS14 |
 | 20 |
| pin 14 IC 74LS14 |
 | 7 |
| 100 nF cap. between pin 14, 7 IC 74LS14 |
| 100nF cap. | between 1,2 ; 21,22 ; 42,43 ; 63,64 |  |
| 100 nF cap. |
 | between pin 9,20 |
| 10 uF/25V tantale |
 | between pin 9 (+) and pin 20 (-) |
