标题: ADP-PIC12C5X/-S [打印本页]
作者: liyf    时间: 2013-9-8 06:11
标题: ADP-PIC12C5X/-S
Adapter for programming PIC12C508 with an Hilo ALL07 Programmer   and HILO ALL03 (Release V9.11 and V9.12)
for Hilo All-07 use adapter file ampu3.exe   (supports Microchip PIC12C508, PIC12C509, PIC12C508(JW), PIC12C509(JW), PIC12C671,   PIC12C672, PIC12C671(JW), PIC12C672(JW), PIC12C508A, PIC12C509A, PIC12C508A(JW),   PIC12C509(JW), PIC12CE518, PIC12CE519, PIC12CE518(JW), PIC12C519(JW), PIC12C673,   PIC12C674.)
I have built my adapter by wiring 2 DIL8 socket in this way:
  name A the socket you'll insert into the ALL07 DIL40 zif socket,
  name B the socket you'll put the pic12c50x into
You have to wire:
  A pin1 -> B pin4
  A pin2 NC
  A pin3 NC
  A pin4 -> B pin8
  A pin5 NC
  A pin6 -> B pin6 (coincident)
  A pin7 -> B pin7 (coincident)
  A pin8 -> B pin1
If the wiring is correct, when you insert the A socket into the zif you
  can verify that:
  ZIF pin17 -> PIC pin4 ZIF pin24 -> PIC pin1
  ZIF pin18 NC ZIF pin23 -> PIC pin7
  ZIF pin19 NC ZIF pin22 -> PIC pin6
  ZIF pin20 -> PIC pin8 ZIF pin21 NC
other explanation of the wiring :
Broches
  PAC40 ---Support DIP8
  17 --------4 MCLR/Pgm
  18 --------NC
  19 --------NC
  20 --------8 Gnd/masse
  21 --------NC
  22 --------6 Data IO
  23 --------7 Clock
  24 --------1 Vcc +5V
作者: HWX0309    时间: 2020-8-30 02:33
谢谢分享引脚关联表。
谢谢楼主给俺留沙发。
