查看: 5052|回复: 8
[转载] 带显示屏可以脱机 ISP 的 USB 全驱动编程器
发表于 2014-11-10 23:14:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
http://www.d-d-s.nl/rk-system.html
这个看起来不错, 带显示屏, 可以 ISP/JTAG.
Uprog portable
- the new series of universal and extreme fast device programmers.
Thanks to USB 2.0 interface and specjalized microprocessor we achived short programming times close to vendor's maximum ratings. Its one of fastest IC programmers on world's market.
Uprog portable is able to working in High Speed and Full Speed mode.
Thanks to usage Compact Flash card programmer can work in stand alone mode without posibillity of usinng PC computer.
Uprog portable support all sizes of Compact Flash cards, since big data files can be supported, what is especially important when big NAND flash memories has to be programmed.
Key features
  • Two operation modes: stand-alone and standard PC-hosted.
  • USB interface - USB 2.0 (HighSpeed and FullSpeed) and USB 1.1 compatible
  • LCD display and keyboard
  • Specialized FPGA based microprocessor (20 ns cycle).
  • One of fastest programmers on the world's market, programming times close to vendor's maximum ratings.
  • In-circuit programming connector (ICP).
  • 48-pins universal independent pindrivers which can provide VPP: 0-30V, VCC: 0.8 - 8V, CLK: ~360Hz-24MHz, GND
  • No adapter required for any DIL devices.
  • Compact Flash card as data depository.
  • Devices supported: EPROM, EEPROM, Flash, SPLD, CPLD, microcontrollers.
  • Adapter Creator feature allows to use many adapters from different providers.
  • Pin contact check feature
  • Test of digital ICs
  • 8-bit EPROM/Flash simulator (option)
  • 16-bit EPROM/Flash simulator (option)
  • Ulogic - Uprog based logic analyzer with pattern generator feature (option)
  • Multi color status LEDs: power, busy, error, good.
  • Banana jack on the case for grounding purpose and ESD protection.
  • Software for Windows 2000/XP/Vista supports many independent programmers simultaneously.
Dimensions: 11 x 17 x 3.5 cm
收藏收藏1 分享分享 支持支持 反对反对
沙发
 楼主| 发表于 2014-11-10 23:16:40 | 只看该作者
板凳
 楼主| 发表于 2014-11-10 23:20:04 | 只看该作者
地板
 楼主| 发表于 2014-11-10 23:22:29 | 只看该作者
Ulogic - digital signal analyser (option).
5#
发表于 2014-11-13 10:30:21 | 只看该作者
看名字以为是liyf 的呢
6#
发表于 2014-11-13 11:13:24 | 只看该作者
program 发表于 2014-11-13 10:30
看名字以为是liyf 的呢
,别说u48pro好像也差不多这外观,只是lcd和键盘在一边,座子和接口在一边而已,不注重外观就只有四四方方的
7#
 楼主| 发表于 2014-11-13 16:15:01 | 只看该作者
这个编程器看起来挺不错, 不好LCD太小, 版主的好象是TFT彩屏 ?
8#
发表于 2014-11-14 14:32:21 | 只看该作者
看名字以为是liyf 的呢
9#
发表于 2014-11-17 15:47:38 | 只看该作者
这个还真挺不错的
GMT+8, 2024-9-28 02:29 , 耗时 0.101823 秒, 21 个查询请求 , Gzip 开启.
