查看: 1505|回复: 0
[待整理] Cisco CatOS基本安全配置详解
发表于 2014-10-13 16:14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
set cdp disable              //禁用cdp
set ip http disable        //禁用http server,这玩意儿的安全漏洞很多的
set logging timestamp enable     //启用log时间戳
set logging server 192.168.0.1   //向192.168.0.1发送log
set logging server 192.168.0.2   //向192.168.0.2发送log
set snmp community HSDxdf        //配置snmp只读通讯字
set ip permit enable snmp        //启用snmp访问控制
set ip permit 192.168.0.1 snmp  //允许192.168.0.1进行snmp访问
set ip permit enable telnet        //启用telnet访问控制
set ip permit 192.168.0.1 telnet  //允许192.168.0.1进行telnet访问
set password                     //配置telnet密码
set enable                     //配置特权密码
set logout 2                   //配置超时参数,2分钟
set banner motd         //配置提示信息
This is a private system operated for UltraTeam.
Authorization from UltraTeam is required to use this system
Use by unauthorized persons is prohibited
set timezone PST-8         //设置时区
set ntp authenticate enable       //启用NTP认证
set ntp key 1 md5 uadsf   //设置NTP认证用的密码,使用MD5加密。需要和ntp server一致
set ntp server 192.168.0.1 key 1 //配置ntp server,server为192.168.0.1,使用1号key做为密码
set ntp client enable     //启用ntp client
GMT+8, 2026-9-1 22:59 , 耗时 0.110175 秒, 19 个查询请求 , Gzip 开启.
