查看: 3862|回复: 2
[资料] USB-FPGA Module 2.01
发表于 2014-11-26 09:39:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
http://www.ztex.de/usb-fpga-2/usb-fpga-2.01.e.html
Features
  • USB 2.0 interface with Mini-USB connector (B-type)
  • Cypress CY7C68013A EZ-USB FX2 Microcontroller (100 pin version)
  • Xilinx Spartan 6 XC6SLX16 FPGA (XC6SLX9 and XC6SLX25 on request)
  • External I/O connector (consisting in two female 2x32 pin headers with 2.54mm grid) provides:
    • 100 General Purpose I/O's (GPIO) connected to FPGA
    • JTAG signals
    • Reset signal
    • External power (4.5 V .. 16 V) input
    • 3.3V output
    • I/O voltage output or input, see External I/O connector
  • 128 MBit on-board Flash memory
    • Allows Bitstream loading from Flash to FPGA (up to 6.5 MByte/s)
    • Accessible from EZ-USB FX2 and from FPGA
  • 128 Kbit EEPROM memory (can be used to store the EZ-USB firmware)
  • 2 Kbit MAC-EEPROM: contains a unique non erasable MAC-address and is used to store firmware settings
  • On-Board power supply:
    • Power source selectable by jumper: USB or External I/O connector
    • 3.3 V: 2000 mA
    • 1.2 V; 1000 mA
  • Temperature range: 0-70°C
沙发
 楼主| 发表于 2014-11-26 09:49:41 | 只看该作者
板凳
 楼主| 发表于 2014-11-26 09:50:05 | 只看该作者
GMT+8, 2026-9-1 14:57 , 耗时 0.378770 秒, 20 个查询请求 , Gzip 开启.
