查看: 334|回复: 0
头文件AT89x051.H
发表于 2011-4-30 11:05:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
头文件AT89x051.H
AT89x051.H
Header file for the Atmel 89C1051U, 89C2051, 89C4051.
Copyright (c) 1995-2000 Keil Software, Inc. All rights reserved.
#ifndef AT89CX051_HEADER_FILE
#define AT89CX051_HEADER_FILE 1
Byte Registers
sfr SP = 0x81;
sfr DPL = 0x82;
sfr DPH = 0x83;
sfr PCON = 0x87;
sfr TCON = 0x88;
sfr TMOD = 0x89;
sfr TL0 = 0x8A;
sfr TL1 = 0x8B;
sfr TH0 = 0x8C;
sfr TH1 = 0x8D;
sfr P1 = 0x90;
sfr SCON = 0x98;
sfr SBUF = 0x99;
sfr IE = 0xA8;
sfr P3 = 0xB0;
sfr IP = 0xB8;
sfr PSW = 0xD0;
sfr ACC = 0xE0;
sfr B = 0xF0;
PCON Bit Values
#define IDL_ 0x01
#define STOP_ 0x02
#define EWT_ 0x04
#define EPFW_ 0x08
#define WTR_ 0x10
#define PFW_ 0x20
#define POR_ 0x40
#define SMOD_ 0x80
TCON Bit Registers
sbit IT0 = 0x88;
sbit IE0 = 0x89;
sbit IT1 = 0x8A;
sbit IE1 = 0x8B;
sbit TR0 = 0x8C;
sbit TF0 = 0x8D;
sbit TR1 = 0x8E;
sbit TF1 = 0x8F;
TMOD Bit Values
#define T0_M0_ 0x01
#define T0_M1_ 0x02
#define T0_CT_ 0x04
#define T0_GATE_ 0x08
#define T1_M0_ 0x10
#define T1_M1_ 0x20
#define T1_CT_ 0x40
#define T1_GATE_ 0x80
#define T1_MASK_ 0xF0
#define T0_MASK_ 0x0F
P1 Bit Registers
sbit P1_0 = 0x90;
sbit P1_1 = 0x91;
sbit P1_2 = 0x92;
sbit P1_3 = 0x93;
sbit P1_4 = 0x94;
sbit P1_5 = 0x95;
sbit P1_6 = 0x96;
sbit P1_7 = 0x97;
sbit AIN0 = 0x90; /* + Analog comparator input */
sbit AIN1 = 0x91; /* - Analog comparator input */
SCON Bit Registers
sbit RI = 0x98;
sbit TI = 0x99;
sbit RB8 = 0x9A;
sbit TB8 = 0x9B;
sbit REN = 0x9C;
sbit SM2 = 0x9D;
sbit SM1 = 0x9E;
sbit SM0 = 0x9F;
IE Bit Registers
sbit EX0 = 0xA8; /* 1=Enable External interrupt 0 */
sbit ET0 = 0xA9; /* 1=Enable Timer 0 interrupt */
sbit EX1 = 0xAA; /* 1=Enable External interrupt 1 */
sbit ET1 = 0xAB; /* 1=Enable Timer 1 interrupt */
sbit ES = 0xAC; /* 1=Enable Serial port interrupt */
sbit ET2 = 0xAD; /* 1=Enable Timer 2 interrupt */
sbit EA = 0xAF; /* 0=Disable all interrupts */
P3 Bit Registers (Mnemonics & Ports)
sbit P3_0 = 0xB0;
sbit P3_1 = 0xB1;
sbit P3_2 = 0xB2;
sbit P3_3 = 0xB3;
sbit P3_4 = 0xB4;
sbit P3_5 = 0xB5;
/* P3_6 Hardwired as AOUT */
sbit P3_7 = 0xB7;
sbit RXD = 0xB0; /* Serial data input */
sbit TXD = 0xB1; /* Serial data output */
sbit INT0 = 0xB2; /* External interrupt 0 */
sbit INT1 = 0xB3; /* External interrupt 1 */
sbit T0 = 0xB4; /* Timer 0 external input */
sbit T1 = 0xB5; /* Timer 1 external input */
sbit AOUT = 0xB6; /* Analog comparator output */
IP Bit Registers
sbit PX0 = 0xB8;
sbit PT0 = 0xB9;
sbit PX1 = 0xBA;
sbit PT1 = 0xBB;
sbit PS = 0xBC;
PSW Bit Registers
sbit P = 0xD0;
sbit FL = 0xD1;
sbit OV = 0xD2;
sbit RS0 = 0xD3;
sbit RS1 = 0xD4;
sbit F0 = 0xD5;
sbit AC = 0xD6;
sbit CY = 0xD7;
Interrupt Vectors:
Interrupt Address = (Number * 8) + 3
#define IE0_VECTOR 0 /* 0x03 External interrupt 0 */
#define TF0_VECTOR 1 /* 0x0B Timer 0 */
#define IE1_VECTOR 2 /* 0x13 External interrupt 1 */
#define TF1_VECTOR 3 /* 0x1B Timer 1 */
#define SIO_VECTOR 4 /* 0x23 Serial port */
#endif
GMT+8, 2026-9-19 07:46 , 耗时 0.291429 秒, 19 个查询请求 , Gzip 开启.
