标题: CH341A 编程器使用说明v1.5 [打印本页]
作者: liyf    时间: 2019-11-16 11:45
CH341A 编程器使用说明
(彩灯版v1.5)2019.11.15
目 录
一、CH341A编程器简介..................................................................................................................3
二、编程器硬件部分.......................................................................................................................4
1、输出电压Vout....................................................................................................................4
a)1.8v拨动开关位置参考.............................................................................................6
b)2.5v拨动开关位置参考.............................................................................................6
c)3.3v拨动开关位置参考(默认).............................................................................6
d)5v拨动开关位置参考................................................................................................6
2、spi输出..............................................................................................................................8
3、TTL输出............................................................................................................................9
4、TTL自检..............................................................................................................................9
5、红外测码...........................................................................................................................11
6、彩灯说明...........................................................................................................................13
7、芯片放置...........................................................................................................................14
8、通用转接板.......................................................................................................................15
9、93xx芯片的放置方式图..................................................................................................16
10、45xx芯片的放置方式....................................................................................................17
11、st95xxx系列汽车存储芯片...........................................................................................18
12、KB901x类芯片接线图..................................................................................................19
13、qfn8转接板....................................................................................................................20
14、bga24转接板..................................................................................................................21
15、bga24 8mm*6mm 4*6球阵列翻盖座.........................................................................22
16、bga24 8mm*6mm 5*5球阵列翻盖座.........................................................................24
17、qfn8 8mm*6mm 翻盖座................................................................................................25
18、qfn8 6mm*5mm 翻盖座................................................................................................26
三、安装驱动.................................................................................................................................27
1、编程器驱动.......................................................................................................................27
2、TTL串口驱动..................................................................................................................27
四、编程器软件.............................................................................................................................28
1、AsProgrammer ..................................................................................................................28
2、ch341 usb编程器软件.....................................................................................................29
五、常见问题及处理方法.............................................................................................................30
1、土豪金版的软件读写32M芯片不正常.........................................................................30
2、AsProgrammer不能读写microchip的93LC46A,93LC66A ......................................30
3、正在读写操作时,操作软件会出现读写状态灯灭掉...................................................30
4、AsProgrammer读出文件比艾科等专业编程器的小......................................................30
5、AsProgrammer读写w25q64fw不正常..........................................................................30
6、win10系统下AsProgrammer读写可能不正常.............................................................30
7、同样芯片型号怎么比你的读写慢...................................................................................30
8、编程器插上电脑有时能识别有时又不能.......................................................................30
9、电压开关已经拔到5V,但是电压只有4.2v.................................................................30
10、USB-TTL检测老是失败...............................................................................................30
11、USB-TTL检测提示不能打开端口错误........................................................................31
12、自动编程总是校验地址00000000错误.......................................................................31
13、红外测码有时能测有时不能.........................................................................................31
CH341A编程器v1.5使用说明.pdf (1.41 MB, 下载次数: 1258)
作者: liyf    时间: 2019-11-20 08:38
14、点自动编程器后在去保护环节卡住不走
芯片放置错误位置或者芯片接触不良,点停止按钮,退出编程状态。重新放置好芯片后,点问号按钮,确认芯片是否能读出id,能读出了说明接触没问题。
作者: yu68805205    时间: 2019-11-21 02:44
先赚一点银两在下载吧好难啊!
作者: yu68805205    时间: 2019-11-21 02:45
先赚一点银两在下载吧好难啊什么情况?
作者: 天天向上    时间: 2019-11-21 17:48
努力回帖!赚银两,赚积分
作者: 阿财_R19XH    时间: 2019-11-25 19:35
不错,好好学习学习
作者: a_tao9999    时间: 2019-12-3 22:06
好好学习学习
作者: weln2020    时间: 2020-1-14 01:30
做产品不易 支持版主
作者: apexmicaa    时间: 2020-1-21 17:44
谢谢楼主分享,支持一下@
作者: nmcfzxd    时间: 2020-2-17 09:01
谢谢楼主分享,支持一下
作者: savfile    时间: 2020-2-19 19:11
谢谢楼主分享,支持一下
作者: wx_goU22RI0    时间: 2020-2-22 16:03
学习了,下一个
作者: starchow_520    时间: 2020-3-5 23:26
赚点银子不容易啊!
作者: mxn007    时间: 2020-9-29 22:18
先赚一点银两在下载吧好难啊!
作者: firepower9966    时间: 2020-9-29 22:47
Is this for sale?
作者: firepower9966    时间: 2020-9-29 22:48
这是出售吗?
很好的设计
作者: liyf    时间: 2020-9-30 08:20
15、出现"连接CH341编程器错误(-1)"提示
a)请安装驱动,参考3.1编程器驱动。
b)检查J1的跳线器是否1-2短接位置,重新拔插编程器。
c)编程器硬件选择不对。菜单栏-->硬件-->ch341av1.5,关闭软件后自动保存设置。
16、出现"连接USBAsp编程器错误(3)"提示
17、读写SST的芯片好慢
这是正常的,主要是这类芯片比较特殊,软件处理这块有待优化。
18、win10下asprogrammer界面错乱
这个是win10系统字体偏大或者缩放引起,设置标准或100%即可解决。
作者: 李小路    时间: 2020-9-30 14:13
谢谢分享!
作者: gswwjm    时间: 2020-12-25 10:00
找点空闲时间来测试一把看看,现在先学习把小板板和针焊接在一起。感谢
作者: ssjl    时间: 2021-2-18 21:08
努力回帖!赚银两,赚积分
作者: wap1003428756    时间: 2022-1-27 16:24
做产品不易 支持版主
作者: wap1003428756    时间: 2022-1-27 16:34
不错,好好学习学习
作者: whmph    时间: 2022-1-28 10:26
各位大神哪有CH341编程器1.7的版本下载
作者: liyf    时间: 2022-1-28 10:33
这是硬件版本
作者: whmph    时间: 2022-1-28 10:55
回去看看我的硬件是哪个版本
作者: liyf    时间: 2022-1-28 10:59
whmph 发表于 2022-1-28 10:55
回去看看我的硬件是哪个版本
最近买的一般是1.6
作者: whmph    时间: 2022-1-29 15:24
路过 看帖回复是美德
作者: 大漠游民    时间: 2022-3-7 12:36
不错,学习学习
作者: hu140229    时间: 2022-4-1 16:25
好好学习学习
作者: aizml1983    时间: 2022-4-3 09:19
学习资料不错,好好学习学习。正需要使用的。
作者: smr12233    时间: 2022-4-3 11:15
先赚一点银两在下载吧好难啊什么情况?
作者: zeppelin    时间: 2022-5-27 06:54
谢谢楼主分享,学习学习
作者: diyrsk138    时间: 2022-5-29 16:36
好东西,学习学习
作者: pang    时间: 2022-6-6 07:00
大家早上好,我来赚银两了
作者: gamekeys    时间: 2023-9-16 00:42
谢谢分享了,支持一下
作者: zdjdhjc    时间: 2023-9-19 07:54
回帖赚银子
作者: qaz    时间: 2024-1-22 11:37
加油加油,好好学习。。
谢谢楼主分享,支持一下
作者: waenzht    时间: 2024-2-21 17:12
感谢楼主提供,辛苦!
积攒银子啊,有点辛苦
作者: zhanghudao    时间: 2024-2-24 19:13
谢谢楼主分享,支持一下,已经现在学习!
