标题: USBtinyISP [打印本页]
作者: liyf    时间: 2011-11-24 21:18
标题: USBtinyISP
USBtinyISP
My new pc doesn't have a parallel port anymore so I couldn’t use the AVR programmer I made before anymore. That's why I decided to build one that works on a USB port.
The design is based on the USBtinyISP design from http://www.ladyada.net/make/usbtinyisp/index.html I removed the 6p connector from the circuit because I don't use that. And I've made a new print that is single sided.
The circuit drawing:
PCB layout
Pictures:
usbtinyisp_bottom.pdf (14.94 KB, 下载次数: 4)
usbtinyisp_silk.pdf (21.19 KB, 下载次数: 4)
作者: 四海★才友电器    时间: 2013-5-16 20:54
英文读不太懂,翻译为中文就好了。
