标题: 研仪Labtool-48UXP的拆机分析,外国的哦 [打印本页]
作者: liyf    时间: 2011-4-17 15:29
48UXP (hw)
February 3rd, 2009 by bushing
Back at 25C3, pytey handed me a rather intimidating piece of hardware. “It’s a flash programmer, but it doesn’t work; I think I broke it with a custom adapter I was working on for it. I don’t have any tools to try to fix it, you want to have a go?”
Here’s the device:
The “Labtool-48UXP” is an “Intelligent Universal Programmer”, with an impressive list of features. Some of the ones that caught my eye were “Four DACs for Vcc, Vpp1, Vpp2 and Vpp3 with 8-bit resolution. Software controllable rises time and current limit protection”, “Logic driver supports pull-up/ pull-down or high impedance on all 48 pins with 2.0V-5V level,” and “The LabTool-48UXP performs device insertion and contact checks before it programs each device. It can detect poor pin contact and devices inserted upside down or in the wrong position.”
I had high hopes for this device — maybe I could write a Mac client for it, or add support for the Wii’s NAND flash chips to it. In any case, I could find virtually no info about this thing online; surely someone had hacked on one of these things before? In any case, before any more fun could be had, I had to get it working, and that required understanding what’s inside. Shall we take a look?
When you open the thing up, you’re faced with 2 stacked boards and a dual-voltage power supply (12v/5v).
The lower board is marked “LabTool-48UXP Control Unit”.
[/url]
In some order, here are the major parts on the board:
The chips marked with ? have the tops sanded off them. The chips marked with * are standard 74HCT logic-series chips — from top to bottom, left to right (like reading a book) we have ’373, ’245, ’373, ’14A, ’245, ’244, ’373, ’374, ’244, ’244.
The upper board is marked “LabTool-48 Driver Unit”.
Still unclear is exactly how the transistors and relays on the first board interact with the latches on the second board. My next post will talk about the software provided by the manufacturer to drive this thing.
作者: hdzl    时间: 2011-4-18 09:09
这个特殊会员是咋整的?头一次见着。有点稀奇!围观
作者: liyf    时间: 2011-4-18 19:32
呵呵,特殊待遇的啊
作者: 万里翔    时间: 2011-5-8 00:21
曾经有台LT-48,卖掉了
作者: liyf    时间: 2011-5-8 02:56
老牌子还是值得信赖的,uxp卖掉就可惜了,还是可以更新的,不像我的不能更新了
作者: xtoqm    时间: 2011-5-9 10:05
坛主还是在校学生?佩服佩服
作者: liyf    时间: 2011-5-9 11:02
那是十几年前的事了
作者: xtoqm    时间: 2011-5-9 11:36
我以为你在学校呢,你那东东早点出来吧,出来了我先订五十套
作者: liyf    时间: 2011-5-9 11:50
谢谢你的支持,我会努力的
作者: program    时间: 2013-10-16 21:37
作者: shangdawei    时间: 2017-4-9 19:21
作者: 喜欢电台    时间: 2017-4-10 17:53
好的资料 要好好学习一下
作者: muelfox    时间: 2021-7-2 18:33
谢谢分享, 一切为了银子
作者: sjuns123    时间: 2023-6-7 16:20
学习学习!
作者: qiao982    时间: 2024-1-21 16:38
好的资料 要好好学习一下
