标题: dfu-programmer 0.62 [打印本页]
作者: liyf    时间: 2013-10-14 12:33
dfu-programmerUSB firmware upgrading for Atmel microcontrollers
SYNOPSISdfu-programmer target[:usb-bus,usb-addr] command [options] [parameters]
dfu-programmer --help
dfu-programmer --targets
dfu-programmer --version
DESCRIPTIONdfu-programmer is a multi-platform command line Device Firmware Upgrade (DFU) based programmer for the flash memory on Atmel AVR, AVR32, XMEGA and 8051 based microcontrollers which ship with a USB boot loader. It supports In System Programming (ISP) for developers and potentially product updates in the field. Those boot loaders are patterned after the standard USB DFU 1.0 class specification, but depend on extensions defined by Atmel to the extent that standard DFU drivers will not work.
To use it, first connect the device to be programmed and ensure that it comes up in DFU mode. The microcontrollers come up in that mode as shipped by Atmel; or they may reenter that mode after a special hardware reset. Then invoke this program to issue one or more DFU commands. You will normally need to start by issuing the "erase" command; the default security policies prevent extracting firmware, to prevent reverse engineering of what is usually proprietary code.
SUPPORTED MICROCONTROLLERSThese chip names are used as the command line "target" parameter.
8051 based controllers:at89c51snd1c, at89c51snd2c, at89c5130, at89c5131, and at89c5132.
AVR based controllers:at90usb1287, at90usb1286, at90usb647, at90usb646, at90usb162, at90usb82, atmega32u6, atmega32u4, atmega32u2, atmega16u4, atmega16u2 and atmega8u2.
AVR32 based controllers:at32uc3a0128, at32uc3a1128, at32uc3a0256, at32uc3a1256, at32uc3a0512, at32uc3a1512, at32uc3a0512es, at32uc3a1512es, at32uc3a364, at32uc3a364s, at32uc3a3128, at32uc3a3128s, at32uc3a3256, at32uc3a3256s, at32uc3a4256s, at32uc3b064, at32uc3b164, at32uc3b0128, at32uc3b1128, at32uc3b0256, at32uc3b1256, at32uc3b0256es, at32uc3b1256es, at32uc3b1512, at32uc3b0512, at32uc3c064, at32uc3c0128, at32uc3c0256, at32uc3c0512, at32uc3c164, at32uc3c1128, at32uc3c1256, at32uc3c1512, at32uc3c264, at32uc3c2128, at32uc3c2256 and at32uc3c2512.
XMEGA based controllers:atxmega64a1u, atxmega128a1u, atxmega64a3u, atxmega128a3u, atxmega192a3u, atxmega256a3u, atxmega16a4u, atxmega32a4u, atxmega64a4u, atxmega128a4u, atxmega256a3bu, atxmega64b1, atxmega128b1, atxmega64b3, atxmega128b3, atxmega64c3, atxmega128c3, atxmega256c3, atxmega384c3
dfu-programmer-win-0.6.2[1].zip (316.87 KB, 下载次数: 5)
源代码
dfu-programmer-code-167-trunk.zip (101.71 KB, 下载次数: 4)
