查看: 2691|回复: 0
[待整理] 英飞凌车载蓝牙系统解决方案
发表于 2015-4-27 21:40:30 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
As market leader in both automotive and wireless technology Infineon has developed a specific Bluetooth solutions offering for the automotive market.
The available product offering ranges from ICs (BlueMoon Single Cellular PMB8761) to HCI modules (PBA31307), up to complete system solutions (BCG) integrating the full protocol stack and speech processing algorithms.
The BlueMoon Single Cellular is a true single-chip solution offering outstanding RF performance over the complete temperature range. Customer with high volumes deciding for board-level integration of a Bluetooth IC can be supported with reference designs and other design services.
Customers requiring standard Bluetooth modules with HCI interface have the choice of a range of available modules. This approach allows fast and easy integration into the infotainment system at low risk.
The Bluetooth Communication Gateway (BCG) represents a fully integrated Bluetooth sub-system, combining Infineon''s outstanding Bluetooth technology with a highly optimized gateway 32bit controller-DSP of the TriCore family. The system offering includes a reference desing and the software package BCI including the Bluetooth protocol stack, profiles, and voice processing algorithms addressing the requirements in an automotive environment.
Infineon''s Bluetooth solutions are designed to support or even to exceed the automotive temperature range
(-40°C...+85°).
Design services and qualified Bluetooth software, specifically adapted to the Infineon Bluetooth products and for automotive applications, are available.
点击获取相关产品信息
GMT+8, 2026-11-18 09:48 , 耗时 2.407358 秒, 22 个查询请求 , Gzip 开启.
