查看: 3172|回复: 0
[待整理] SiRFatlasVI开发指南
发表于 2015-4-27 23:58:27 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
SiRFatlasVI描述
          The SiRFatlasVI integrates an ARM Cortex 9 CPU core, up to 1GHz and targets low-end and mid-range products. As the latest infotainment SoC from CSR, SiRFatlasVI is designed to enable user experience of advanced graphics, location and connectivity on mainstream automotive dashboards at competitive overall cost and fast time-to-market, with pre-optimised GNSS, Bluetooth and Wi-Fi.
          SiRFatlasVI产品详细信息
          平台解决方案
          基本软件
  •                 Includes BSPs to support location, graphics, and multimedia
  •                 Windows CE 6.0, Android 4.0 and Linux
          本地软件
  •                 SiRFInstantFix extended ephemeris services
  •                 SiRFDiRect GPS/Dead Reckoning software for continuous and accurate
          程序软件
  •                 CSR Bluetooth stack / profiles, Wi-Fi driver
  •                 CSR cVc echo-cancellation software
          软件服务
          Bluetooth and Wi-Fi interoperability (IOP) and coexistence testing.
          其它平台组件
          CSR3000 GNSS companion RF, CSR8000 Bluetooth and Bluetooth LowEnergy (CSR μEnergy), CSR6000 Wi-Fi, CSR1300 Single-Mode Bluetooth Low Energy, Vaddis DVD Servo, Camera solution.
          技术规格
          CPU
  •                 ARM CortexA9: 800MHz@2000DMIPS, and up to 1GHz@2500DMIPS
  •                 32KB I-cache / 32KB D-cache, ARM NeonTM
          集成全球卫星导航基带
          Support for GPS, Glonass, Galileo, and Compass (after a software upgrade) , with external CSR3000 RF chip SiRFDRive dead reckoning.
          内存
          16-bit DDR3, DDR3L, LPDDR2 up to 512MB
          NAND 和启动设备
  •                 Direct boot supported from SDXC, SLC NAND flash, managed NAND
  •                 SLC/MLC/TLC 512B/2K/4K/8K/16KB page, 64/128/192/256 pages per block
  •                 8-bit data width with 12/24/40/60-bit ECC engine
  •                 eMMC 4.4 support
          2D/3D 图形处理
  •                 Up to 8M triangles/s and 250Mpixels/s fill-rate
  •                 OpenGL ES 1.1/2.0, OpenVG 1.1 support
  •                 Resolution up to 1280 x 720
  •                 Four hardware overlays
          多媒体
  •                 Hardware Video Post Processor capable of color space conversion and advanced deinterlacing (scaling 1/8-8)
  •                 Independent brightness/contrast control
  •                 8-bit VIP supporting up to 5M pixel camera and CCIR656 input
  •                 Left-right mirror function to support instant backview
          集成I/O和模拟功能
  •                 Two USB 2.0: one with on-chip PHY, one with external PHY
  •                 UART/I2S/SPI/I2C
  •                 Touch-screen controller and audio codec
          封装
          Automotive and industrial: 13.4 x 12.6 x 1.16mm 0.65mm pitch 362-ball FCBGA
          Temperature range for industrial parts: -40~+85℃
          主要特点
  •                 Enables greater user experience at similar BOM cost compared to
          previous-generation Atlas product: 3x CPU DMIPs, 3x graphics
          and 6x multimedia performance improvement, enabling the driver
          to experience more fluid user interfaces, richer map graphics, and
          concurrent navigation and up to 720p media playback
  •                 Integrated multi-satellite GNSS capabilities support all global
          navigation systems, providing flexibility and improved satellite
          acquisition and location tracking in challenging situations like
          urban canyons. Support for industry-leading dead-reckoning
          technologies is also provided
  •                 Value leadership: powerful performance, competitive BOM cost,
          direct local R&D support
  •                 Supports concurrent multiple user scenarios on in-vehicle
          infotainment system, PND, MID, and other modern multifunction
          devices
  •                 Short time-to-market at low overall cost: High SoC integration,
          simplified hardware design including a PCBfriendly 0.65-mm ball
          pitch package, fully qualified BSPs with location and connectivity
          platform solutions, plus local engineering support
          推荐阅读:
          摘要:SiRF Technology推出的SiRFatlasIV多功能定位系统处理器针对高量导航及定位感测产品开发设计,透过此款高效能定位引擎,加上比现有入门级系统大上一倍的记忆体频宽,SiRFatlasIV平台不但将材料与整体系统成本压至最低,更可带给制造商顶尖的定位与多媒体效能。
          摘要:SiRFatlasVI SoC与以前的SiRFatlasV芯片相比,在几乎相同的BOM成本下,CPU速度和图像处理能力分别是原来的3倍,多媒体性能则是原来的6倍。这些性能的提升使驾驶员能够体验到更加流畅的用户界面、更丰富的地图信息,以及在导航的同时实现多媒体回放功能。
          摘要:As the latest infotainment SoC from CSR, SiRFatlasVI is designed to enable user experience of advanced graphics, location and connectivity on mainstream dashboards.
GMT+8, 2026-11-18 05:28 , 耗时 0.160871 秒, 19 个查询请求 , Gzip 开启.
