查看: 219|回复: 0
Transformers for the SV811/572's 变压器阻抗
发表于 2011-4-26 15:46:03 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
TubePlate Load
SV811-34.5k to 12k ohms
SV811-105k to 12k
SV572-34k to 12k
SV572-105k to 12k
SV572-306k to 20k (negative feedback recommended)
SV572-1606k to 30k (negative feedback recommended)
ModelPlate LoadBest Application
Audio Electronic Supply OPT-1268k ohmsone -3, -10 or SV572-30
Audio Electronic Supply OPT-12712k ohmsone -3, -10 , -30 or SV572-160
Audio Note 5KPSE 75W5k ohmsone -3 or -10
Audio Note 10KSE 30W10k ohmsone -3, -10 or SV572-30
Audio Note 10KSE 50W10k ohmsone -3, -10 or SV572-30
Bartolucci 7.8K 15W7.8k ohmsone -3, -10 or SV572-30
Bartolucci 10K 30W10k ohmsone -3, -10 or SV572-30
Electra-Print E18B6.2k ohmsone -3 or -10
Electra-Print E48B1.8k ohmsthree or four -3 in parallel
Electra-Print MT5KB5k ohmsone -3 or -10
Electra-Print MT6KB6k ohmsone -3, -10 or SV572-30
Electra-Print FT4KB4k ohmsone SV572-3
Hammond 1628SE5k ohmsone -3 or -10
Hammond 1629SE6.5k ohmsone -3, -10 or SV572-30
Hammond 1640S1.25K ohmsthree or four -3 in parallel
One Electron UBT-24.8k ohmsone -3 or -10
One Electron UBT-11650 ohmsthree -3 in parallel
Tango FW-150-10SR10k ohmsone -3, -10 or SV572-30
GMT+8, 2026-9-14 08:15 , 耗时 0.082507 秒, 20 个查询请求 , Gzip 开启.
