查看: 224|回复: 0
max7219驱动程序
发表于 2011-4-30 14:15:18 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
max7219驱动程序
//max7219 led drive program
//for 51 mcu
//designed by zhaoliang
//2005-6-12 13:52
#i nclude
//common part
#define HIGH 1
#define LOW 0
#define TRUE 1
#define FALSE 0
#define ZERO 0
#define MSB 0x80
#define LSB 0x01
//max7219 part
#define DECODE_MODE 0x09
#define INTENSITY 0x0A
#define SCAN_LIMIT 0x0B
#define SHUT_DOWN 0x0C
#define DISPLAY_TEST 0x0F
//pin defined
//change this part at different board
sbit LOAD=P1^2; //MAX7219 Load-Data Input: rising edge pin 12
sbit DIN=P1^1; //MAX7219 Serial-Data Input: rising edge pin 1
sbit CLK=P1^0; //MAX7219 Serial-Clock Input: maximum 10MHz pin 13
//function define
void Write_Max7219_byte(unsigned char temp);//write max7219 a byte
void Write_Max7219(unsigned char address,unsigned char dat);//write max7219 command and data
void Init_Max7219(void);//Initize max7219
//test program display from 1"8
void main(void)
unsigned char i;
Init_Max7219();
while(TRUE)
for(i=1;i<9;i++)
Write_Max7219(i,i);
unsigned char i;
for (i=0;i<8;i++)
CLK=LOW;
DIN=(bit)(temp&MSB);
temp<<=1;
CLK=HIGH;
LOAD=LOW;
Write_Max7219_byte(address);
Write_Max7219_byte(dat);
LOAD=HIGH;
Write_Max7219(SHUT_DOWN, 0x01); //Normal Operation XXXXXXX1 Shutdown Mode XXXXXXXX0
Write_Max7219(DISPLAY_TEST, 0x00); //Normal Operation XXXXXXX0 Display Test Mode XXXXXXXX1
Write_Max7219(DECODE_MODE, 0xff); //Decode Mode Select D7"D0 1 B decode 0 No decode
Write_Max7219(SCAN_LIMIT, 0x07); //SCAN LIMIT 0"7 0xX0"0xX7
Write_Max7219(INTENSITY, 0x04); //Set Intensity 0xX0"0xXf
max7219 C语言驱动程序,此经过调试。
#define byte unsigned char
//#defineN_NOP_nop_();//_nop_();_nop_();
//MAX7219
//管脚,变量和常数定义;DEFINE
#defineModel_addr0x09// X9 H
#defineBright_addr0x0a// XA H
#defineLimit_addr0x0b// XB H
#defineShutd_addr0x0c// XC H
#defineTest_addr0x0f// Xf H
#defineSet_Normal0x00//进入正常而非测试工作方式
#defineSet_Halt0x00//进入停机工作方式?
#defineSet_Model0xff//将BCD码译成B码;
#defineSet_Bright0x04//占空比为15/32;
#defineSet_Limit0x07//8位显示方式;
#defineSet_Shutd0x01//进入正常而非停机工作方式?
sbitDIN  =P1^0;
sbitLOAD =P1^1;
sbitCLK  =P1^2;
bitbdatabonceinit7219;
//函数声明ROPERTY
voidInit_7219_begin(void);
voidInit_7219(void);
voidwrite_one_8279(byte addr,byte mydate);
//函数定义;FOUNCTION
{//MAX7219显示型号时的初始化;
write_one_8279(Model_addr,0x00); //将BCD码译成B码?
write_one_8279(Bright_addr,Set_Bright);//占空比为15/32?
write_one_8279(Limit_addr,Set_Limit); //8位显示方式;
write_one_8279(Shutd_addr,Set_Shutd); //进入正常工作方式
voidInit_7219(void)
{//MAX7219正常工作时的初始化;
write_one_8279(Shutd_addr,Set_Halt);//进入停机工作方式
write_one_8279(Model_addr,Set_Model); //将BCD码译成B码?
write_one_8279(Shutd_addr,Set_Shutd); //进入正常而非停机工作方式
write_one_8279(Test_addr,Set_Normal); //进入正常而非测试工作方式
voidwrite_one_8279(byte addr,//要写入的位置;
byte mydate)//要写入的数据;
{//写数据给MAX7219函数;display data
register byte i;
LOAD=0; //-\_
for(i=0;i<8;i++)
_nop_();
CLK=0;//-\_
if(addr & 0x80)
DIN=1;
else
DIN=0;
_nop_();
CLK=1;//_/-
addr=addr<<1;
for(i=0;i<8;i++)
_nop_();
CLK=0;//-\_
if(mydate & 0x80)
DIN=1;
else
DIN=0;
_nop_();
CLK=1;//_/-
mydate=mydate<<1;
LOAD=1;//_/-
GMT+8, 2026-10-7 16:31 , 耗时 0.247813 秒, 19 个查询请求 , Gzip 开启.
