查看: 1739|回复: 0
[待整理] 在Cortex-M3处理器上运行ARM7TDMI处理器软件
发表于 2014-10-12 15:42:45 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 Introduction
        The first question software developers will consider when looking at running ARM7TDMI processor software on a Cortex-M3 processor is: "How much time and effort is it going to take?" The answer is: “practically zero”. A simple re-targeting compilation will be all that is required in the vast majority of cases. Once the software is running, the developer may wish to consider enhancing it to exploit the new functionality of the Cortex-M3 processor not available on the ARM7TDMI processor. This whitepaper will explain how quickly and easily ARM7TDMI processor code can be ported to the Cortex-M3 processor, and how to use the additional features introduced with Cortex-M3 processor and the v7-M architecture to optimise software for size, power and maintainability.
        点击此处查看全文
GMT+8, 2026-11-26 08:30 , 耗时 0.453745 秒, 21 个查询请求 , Gzip 开启.
