查看: 2014|回复: 0
[电路图] 流水灯电路(含源程序代码)
发表于 2011-6-5 06:32:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
流水灯电路(含源程序代码)
其实现程序:
#i nclude
unsigned char RunMode;
//**********************************System Fuction*************************************************
void Delay1ms(unsigned int count)
unsigned int i,j;
for(i=0;ifor(j=0;j>8)&0x00FF);
void InitialCPU(void)
RunMode = 0x00;
TimerCount = 0;
SystemSpeedIndex = 10;
P1 = 0x00;
P0 = 0x00;
P2 = 0xFF;
P3 = 0x00;
Delay1ms(500);
P1 = 0xFF;
P0 = 0xFF;
P2 = 0xFF;
P3 = 0xFF;
SetSpeed(SystemSpeedIndex);
Display(RunMode);
//Mode 0
unsigned int LEDIndex = 0;
bit LEDDirection = 1,LEDFlag = 1;
void Mode_0(void)
LEDShow(0x0001>LEDIndex);
LEDIndex = (LEDIndex+1)%16;
//Mode 2
void Mode_2(void)
if(LEDDirection)
if(LEDIndex==15)
LEDDirection = !LEDDirection;
GMT+8, 2026-11-29 14:02 , 耗时 0.207518 秒, 19 个查询请求 , Gzip 开启.
