查看: 1503|回复: 0
[电路图] 门铃电路图-Birdie Doorbell Ringer
发表于 2011-6-5 07:22:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
门铃电路图-Birdie Doorbell Ringer:Notes1 is of experimental value. Start with 220ohms or so and modify to suit your needs.The transistor is a general purpose kind and is not critical;almost any pnp type will work.
GMT+8, 2025-11-9 10:50 , 耗时 0.088563 秒, 18 个查询请求 , Gzip 开启.
