查看: 3099|回复: 1
[待整理] PRECHARGE 方式参考
发表于 2014-10-5 10:44:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PRECHARGE 方式参考
1) auto-precharge is a read- or write- command with precharge.At the end of the read or write cycle, the bank will be precharged,and available t(RP) later for a bank activate command.precharge is a seperate command cycle to a particular (or all banks). A precharge command will close any open banks, and the bank(s) will then be available for activation t(RP) later.  (See datasheets for t(RP)).
2) there are two-modes self-refresh and auto-refresh.  Auto-refresh is similar to the old CBR (CAS before RAS) refresh, where an internal counter stores the row and column, and each is incremented on a auto-refresh cycle. self-refresh is designed to keep the contents of memory while in a  owerdown type situation.  The internal counters activate and perform a series of internal refresh operations.  When exiting self-refresh mode, I believe you have to execute
a certain number of auto-refresh cycles, to ensure the device is fully refreshed.
GMT+8, 2026-9-17 00:39 , 耗时 0.085186 秒, 17 个查询请求 , Gzip 开启.
