查看: 6283|回复: 2
MSP430 Reflow Oven
发表于 2014-10-7 21:31:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Project Pics:
Schematic:This is my old V1 schematic. Todo if you want a better board:
-Use a MSP430G2553 MCU (more pins and flash)
-Use a non EOL thermocouple driver IC: MAX31855KASA+
-Add in a FT230XS for a USB interface
-Add flyback protection to relay LSD if a mechanical relay is used.
Full size at link:
Oven: Convection (30 usd)
http://www.walmart.c...-Steel/16913546
Oven: IR (recommended that you use an IR oven of sorts)
http://www.walmart.c...sserie/19411514
C# GUI for live plotting:
Here is the BOM:
Update: Schematic has most Part #s on it
Thermal-couple: (Important that it is low thermal mass and rated for temp range)
Digikey: 290-1911-ND
Thermal-couple IC:
MAX31855KASA+
MAX31855KASA+T
Relay: (this is a mechanical relay. I salvaged a SSR for my V2. I highly recommend you use an SSR for long life and quicker switching times)
Digikey: T9AS1D22-5-ND (Relay)
Misc Digikey Part # (Part Discription)
MC78M05CDTGOS-ND (5V regulator Dpak)
445-1590-1-ND ( CAP CER 1.0UF 25V Y5V 0805)
754-1133-1-ND ( LED 2X1.2MM 630NM RD WTR CLR SMD)
754-1127-1-ND (LED 2X1.2MM 570NM GN WTR CLR SMD)
CP-102B-ND (CONN POWER JACK 2.5MM PCB CIRC)
785-1112-1-ND (MOSFET N-CH 20V 25A TO-252 (Relay))
IRLML6344TRPBFCT-ND ( MOSFET N-CH 30V 5A SOT23 (SSR Load))
RMCF0805JT100KCT-ND ( RES 100K OHM 1/8W 5% 0805 SMD)
RMCF0805JT47K0CT-ND ( RES 47K OHM 1/8W 5% 0805 SMD)
RMCF0805FT499RCT-ND ( RES 499 OHM 1/8W 1% 0805 SMD)
296-8247-5-ND (IC 8-BIT SHIFT REGISTER 14-SOIC)
296-28430-1-ND (IC MCU 16BIT 20TSSOP)
RMCF0805JT1K00CT-ND ( RES 1K OHM 1/8W 5% 0805 SMD)
CT94EY104-ND (TRIMMER 100K OHM 0.5W TH)
MCP1700T3302ETTCT-ND ( IC REG LDO 3.3V 250MA SOT23-3)
+ a 16x2 LCD display
+ some dip headers that are used for jumping and programing.
+ 5mm/.2in lead spacing terminal headers for relay and thermocouple input.
收藏收藏1 分享分享 支持支持 反对反对
板凳
发表于 2015-10-17 22:03:20 | 只看该作者
感谢楼主提供这么好的资料
GMT+8, 2026-4-6 00:39 , 耗时 0.174327 秒, 20 个查询请求 , Gzip 开启.
