查看: 9878|回复: 4
ControLeo2 Reflow Oven Controller
发表于 2017-2-19 15:17:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
回流焊控制器,开源的,方便自制
ControLeo-master.zip (62.94 KB, 下载次数: 0)
ControLeo2-master.zip (65.37 KB, 下载次数: 0)
ControLeo2 reflow ovens meet demanding requirements
Must be capable of high-temperature lead-free reflow (240°C) as well as leaded reflow
Must be capable of reflowing a 8" x 10" board:
        - Must not burn the components or the board
        - Must reflow the entire board and not leave parts unsoldered
Must following industry-standard profiles for pre-soak, soak and reflow phases
The challenges of building a reflow oven
Lead-free solder requires higher temperatures than leaded solder.  Leaded solder is dangerous and socially irresponsible so you shouldn't be using it!  Take a look at a typical reflow curve for lead-free solder:
It is easy to think that the most important part of the reflow curve is the maximum temperature of 255°C (480°F).  Yes, it is important to build an oven that is capable of reaching those temperatures.  However, another important number is the rate-of-rise of temperature at the higher temperatures.  At higher temperatures it becomes increasingly difficult to increase the temperature.  You run the risk of damaging sensitive components if the reflow takes too long, and you can create hot spots (damaged components) and cold spots (no solder reflow) if you run the elements full blast.
There are a lot of other problems that can occur if the reflow profile isn't followed.  Components can be damaged from thermal shock or cracking, solder paste can splatter which can lead to voiding in array type packages, and the solder paste could oxidate or the flux not fully activate.  If the maximum allowable temperature of IC's is exceeded, it can damage the internal dies of components and foster intermetallic growth leading to shortened MTBF (mean time before failure) numbers.  The time-above-liquidus and cooling rate also affect the quality of the resulting solder joint.
What makes ControLeo2 the best reflow oven controller?
The ControLeo2 controller and the oven built in the build guide should be considered top-of-the-line.  A lot of engineering and experience has gone into making the ControLeo2 reflow oven, and there are currently more than 800 customers world-wide using ControLeo2.If you are only doing small boards and using leaded solder paste you can get away with a less-capable controller and a poorly insulated oven.  But how much is your time worth? What is the value of the components you plan to use?  What is the turn-around time to order new boards or components when they get heat-damaged?  Do yourself a favor and build yourself a great reflow oven.  Do it once, and do it right!
ControLeo2's advantages:
  • Four outputs
    Control convection fans and heater elements individually.
  • Better heat distribution
    Having control over individual heating elements allows you to keep heat away from sensitive components.
  • Hot-spot elimination
    Intelligent software manages element on-time, reducing hot and cold spots in the oven.
  • Better heat direction
    Intelligent software controls whether heat comes from the top or bottom, depending on the reflow phase
  • Better current management
    Elements are turned on and off independently eliminating the current spikes common in single-relay controllers
  • Ready-to-run
    No programming needed. Just configure the fans/elements your oven has and the reflow wizard will do the rest. No need to connect ControLeo2 to a computer or write any software!
  • Proven hardware
    ControLeo2 is based on the original ControLeo, which has been field tested for more than a year. ControLeo was based on the Arduino Leonardo - another proven design.
  • Open-source
    ControLeo2 is fully compatible with the Arduino programming environment, and runs Arduino Leonardo sketches. A library and 15 sample programs for ControLeo2 has been posted to GitHub.
  • Reflow Wizard
    Intelligent software makes it easy to get your oven up and running. Ensures consistent results, run after run.
  • Reflow feedback
    If you connect ControLeo2 to a computer you can track the reflow progress and get data to plot a reflow temperature graph.
  • Servo support
    Supports industry-standard servos, so the oven door is automatically opened at the end of the reflow cycle to start the cooling process.
  • Baking
    The baking mode supports a full range of temperatures, and a duration of up to 18 hours.
  • Build guide
    Our comprehensive build guide take you step-by step through building your own oven.
  • J-STD-020 compliance
    The Reflow Wizard is aware of the standards governing reflow ovens, and will auto-tune your oven so that it conforms to them.
The alternatives
Cheap China reflow oven (T962/T962A)
This oven has 4 infrared elements located directly above the boards.  There are no heating elements below the boards.
  • Infrared is absorbed at different rates, so expect darker components to heat up much quicker than lighter ones.
  • The oven does not conform to the J-STD-020 reflow standard.  Specifically, it fails to meet requirement 3.2.2: "It is required that this equipment use IR to heat only the air and not directly impinge upon the SMD Packages/ devices under test."
  • All the heat comes from the top.  Imagine trying to reflow a microcontroller - the black microcontroller will absorb a lot of the infrared heat while shading the PCB underneath it.  This creates a huge temperature differential!
Oven with single ON/OFF control
It is possible to build an oven with a single ON/OFF relay controlling power to the oven, but having control over individual heating elements has its benefits:
  • Better heat distribution.  Keep heat away from sensitive components as much as possible.
  • Better control for hot-spot elimination.
  • Better control over heat direction.
    Pre-soak = rapid rise in temperature. The lower elements are on full-blast. The upper elements are on half of the time.
    Soak = stabilize temperature of PCB and components. The lower elements are on 3/4 of the time. The upper elements are on 1/4 of the time
    Reflow = heat the solder and pads rapidly. The lower elements are on full-blast. The upper elements are on most of the time.
  • Better control over current draw. Instead of all-on/all-off, you can keep current draw at a more consistent level.
Hot plate
Here all the heat comes from the bottom, which is great for keeping heat away from sensitive components. Unfortunately:
  • Lead-free reflow is not possible.  You'll burn the PCB long before the solder reflows.
  • No good automation means you need to keep a close eye on the reflow.
  • How do you follow the recommended reflow profile?
Reflow Wizard software
ControLeo2 ships with the "Reflow Wizard" software installed. The software is open-source and has 3 parts:
  • Test the outputs - helps you verify that the heater elements and convection fan (if applicable) work.
  • Oven setup - this part allows you to configure what each output controls. You can also set the maximum reflow temperature and door servo positions.
  • Reflow - This is where the magic happens!
The Reflow Wizard starts off in "learning mode". It looks at the configured hardware and maximum temperature, then takes an educated guess at how to achieve the correct reflow profile. It takes a few test runs to tune the duty cycle settings for each phase of the reflow cycle. Once it conforms to the J-STD-020 reflow standard, it exits learning mode. From then on, you'll get consistent runs time after time. The Wizard will continuously monitor the runs and make tiny adjustments if necessary.You can follow the Wizard's performance and commentary by connecting ControLeo2 to a computer using USB.
The firmware running on ControLeo2 can be easily updated, following these instructions.
Step-by-step build instructions
Complete step-by-step instructions for building your own reflow oven can be found here.
ControLeo2 Test and Setup menu
ControLeo2 in action
ControLeo2 is open
There is no need to program ControLeo2 at all, but if you're a software guru you can tinker to your heart's content. We've open-sourced all the software we've written for ControLeo2, including the Reflow Wizard. The software consists of a single Arduino library that controls all of ControLeo2's functions, as well as 15 sample programs. You can find everything on GitHub (https://github.com/engineertype/ControLeo2)ControLeo2 uses the standard Arduino environment. The library should be installed into your Arduino environment using the instructions found here: http://arduino.cc/en/Guide/Libraries. The single ControLeo2 library gives you access to all of ControLeo2's functionality. Installing the library also installs all the sample code we've written for it.
In Arduino, select the board as "Arduino Leonardo". Your sketches can then be sent to ControLeo2 using its micro-USB port.
ControLeo2 is expandable
ControLeo2 provides both 5V and 3.3V (max 80mA) to power additional components. There are 3 pins available for digital I/O (D3 is used for the servo).
ControLeo2 enclosure
ControLeo2 uses a quality off-the-shelf flame-retardant ABS plastic enclosure with a textured finish. The holes are CNC machined to perfectly fit ControLeo2. The result is a high quality, tight fitting case that looks very good. We are thrilled with this enclosure. Only the lid has holes; you'll need to make a hole to route your wires through the case.
ControLeo2 specifications and features
  • ATmega32u4 microcontroller with Arduino Leonardo boot loader
    • 32Kb Flash memory
    • 2.5Kb SRAM
    • 1Kb EEPROM
  • LCD display - 2 lines x 16 characters.
  • 4 relay outputs - relays are connected using screw terminals or the 6-pin relay header (4 outputs, +5V, GND). The outputs provide up to 220mA at 5V. The outputs support connections to solid-state relays (SSRs) or mechanical relays
  • Buzzer - 80db at 10cm
  • 2 momentary switches - for user input.
  • ABS plastic case - custom fit, flame-retardant (UL94-5VA)
  • MAX31855KASA thermocouple - capable of reading temperatures from -200°C to 1350°C using a k-type thermocouple.
  • Input voltage: 5V (USB or screw terminals) - For reliability and longevity, the screw terminals should be used to power ControLeo2. For solid-state relays, the 500mA provided by USB is sufficient to power ControLeo2 and the relays. For mechanical relays please use a 1000mA 5V power supply connected to the screw terminals.
  • Pre-loaded software - Reflow Wizard
居然还配有diy指南
Building a reflow oven
This guide will show you how to build a great toaster reflow oven.  It isn't difficult to build your own oven, and the result can be equal or better than commercially available ovens.  Building it yourself will give you a better indication of what to look for, how it works and how to tune it to get excellent results.
The reflow oven build described here is fully capable of fine pitch lead-free soldering at very high temperatures, and can do it consistently and reliably.  The entire tray can be filled with PCB's, and all will reflow perfectly.  It uses ControLeo2, a 4-relay programmable reflow oven controller.
Choosing an oven to convert to a reflow oven
This guide assumes access to a 110VAC 15A outlet.  You may have access to a higher voltage or amperage outlet, in which case you can choose a larger oven with a higher power output.  To avoid tripping the fuse, we'll consider 1500W as the total allowable power draw.  Here are the parameters in choosing the oven used in this guide:
  • Small - A smaller oven means less metal to heat up.  Smaller is definitely better!
  • Power - Choose an oven that is powerful, but won't trip the fuse or overload the wiring.
  • Elements - You need some elements on the top and some on the bottom to control where the heat comes from.  Avoid resistive heating elements if possible because of their large thermal intertia.  The more elements the better because good coverage helps to reduce hot and cold spots.
  • Convection fan - This is definitely nice to have but isn't necessary.  If you choose an oven with convection fan make sure there is enough space to mount the relays within the oven!
For this guide we found a suitable oven on Amazon.com.  It was a brand new Black & Decker T01303SB toaster oven for just $30 shipped!  Black & Decker sells many ovens with the same chassis, but with different controls, color or handle design so your oven may not look exactly like this one.  It doesn't have a convection fan and the power consumption is 1150W.  The "low" power consumption means we can add an additional heating element without blowing fuses.  There are 2 heating elements - 600W on top and 550W on the bottom. The area for PCB's is 8"x10.5" (200mm x 260mm).  Perfect!
Build overview for other oven types
The oven in this guide may be unavailable in your area, or you may want to use a different oven - perhaps with a convection fan.  A convection fan is nice to have but most convection ovens are larger, cost more and are more difficult to modify.  The Black & Decker oven used in this guide is 10 liters and runs off 110V.Tips for Europeans (and other 240V countries):
  • Look at the forum discussion here and other ControLeo2 ovens here.
  • Do not try to run a 110V oven through a 110V/240V converter!  The power requirements are huge, as are the conversion losses.  Use an oven designed to run on 240V.
  • Some 240V ovens use two 120V elements wired in series.  This is fine if there are 2 bottom elements in series, or 2 top elements in series - but if you only have one element at the top and one at the bottom then they must be 240V elements.  If the oven supports "top heating" and "bottom heating" then most likely they are 240V elements (good).
  • Do not connect 120V elements to a 240V supply!  P = V2/R so wiring them this way will consume 4 times the power and likely burn out or melt the heating element.
Consideration is given to the current draw of the oven.  In USA, most circuits can handle 15 Amps so the maximum draw is 15A x 110V = 1650 Watts.  For a continuous load this value should be derated by 20%.
ControLeo2 can control 4 relays.  In this guide the 4 outputs are bottom element, top element, boost element and unused.
Example 1: Non-convection oven with 2 heating elements totaling 1150W
This describes the oven used in this guide.  Use a 350W boost element.  This keeps the total power consumption a safe 10% below the 1650W maximum so all elements can be on at the same time.
Example 2: Convection oven with 4 heating elements totaling 1500W
An oven like this one has 4 elements.  The bottom elements are both 300W and the top are 450W.  It is only slightly larger than the oven used in this guide, and in unmodified temperature testing it proved to be slightly better than the oven in this guide.
  • A boost element should be added, but doing this will put the power draw beyond what a 15A circuit can provide.  You may have access to a 20A circuit - great!  If you don't add a boost element you'll need to go overboard with insulation.  In addition to insulating the inside of the oven (Reflect-A-Gold and Boom Mat) you should also add some ceramic blanket insualtion between the oven chamber and the outer shell.
  • The highest wattage elements are on the top - not good.  It is best to remove all the elements, install the insulation and then replace them, with the highest wattage elements at the bottom.  Best to cut the wires and splice them back together using a butt connector.
  • Use 3 relays: one for the top elements, one for the bottom and one for the convection fan.  The convection fan could be wired to be on all the time, or you can use a mechanical relay or small SSR to control it.
  • Add insulation between the oven chamber and outer shell.  This is a big oven, and you need all the help you can get to ensure uniform temperatures that can follow reflow profiles.
  • For the PCB tray, you can use an aluminum tray resting on the wire rack.  Remove as much of the wire as you can to reduce thermal mass.
If you are considering using a convection oven, then blog 1, blog 2 and these photos may help you.
Is a boost heating element necessary?
Common problems in home-made reflow ovens (or cheap commercial ovens) are hot and cold areas.  A cold spot is an area that doesn't get enough heat to activate the flux at the right time, and allow the solder to reach liquidous temperature and reflow. A hot spots is an area that get too much heat and results in warped or blistered boards.  Components can discolor, but some of the worst damage is what you can't see; the mean-time-before-failure (MTBF) of burnt IC's can be severely compromised.How does the boost element help?
  • Heat comes from an additional location, helping to distribute the heat around the oven.
  • The bottom element can be run cooler, so that it isn't an intensely concentrated heat source.
  • It is installed at the bottom of the oven, keeping heat away from sensitive components.
Is insulation necessary?
Good insulation is absolutely necessary when building your own reflow oven.  It is almost impossible to have too much insulation.  If you're using leaded solder paste and only reflowing a single small PCB at a time then it is possible without insulation.  However, the goal in building this oven is to be able to use the entire oven tray for PCB's using lead-free paste.  Quality insulation capable of withstanding high temperatures is expensive but worth it.  We recommend Reflect-A-Gold and Boom Mat.In this guide, Reflect-A-Gold and BoomMat are used inside the oven to prevent heat loss to the steel oven walls.  You can also add insulation to the outside of the oven chamber (and inside the outer shell) to further reduce heat loss.  A fiberglass welding blanket or ceramic blanket insulation work well.  A high-temperature silicone glue can seal the air gaps between the oven panels and you can use Nomex high-temperature gasket to reduce the air gap around the oven door.
Quality insulation is not cheap
There is fake Reflect-A-Gold available on the Internet.  It looks the like the real deal, and test results show the insulating properties to be very similar.  However, the adhesive on this tape doesn't stand up to the high reflow temperatures as can be seen here and here.  Some insulation (we're looking at you, Heatshield Products) rated to higher temperatures than Reflect-A-Gold don't work as well.
How does insulation help?
  • It reduces the thermal mass of the oven, because less heat gets absorbed by the steel walls.
  • By reflecting heat, it helps to eliminate hot and cold spots in the oven.
  • Good insulation means less energy is needed to reach high temperatures.  This means the heating elements can run cooler, further helping to even out temperatures in the oven.  For this particular oven, the bottom element runs at a 95% duty cycle without insulation, but just 60% when insulated.
Use insulation and use a lot of it!  Once you see the great results you get you'll increase the number and complexity of the boards you design.  Do it once, and do it right.
Thermocouples
One is good, more is unnecessary.  If the desire is to get an average reading you can connect multiple thermocouples in parallel.  Thermocouples generate a micro-voltage that is read by the MAX31855 IC, so wiring them in parallel will give you that average.  If the desire is to measure temperature variance around the oven, the best method is to use Temperature Test Labels, as shown here.  This will give you a more accurate picture of the variance and let you know where the hot and cold areas are in the oven.Non-convection ovens are inherently left-right temperature balanced.  Top-bottom imbalance is expected (and desired).  Front-back imbalance will occur because of the wattage and location of the heating elements, type of insulation and the oven door.  A convection fan may reduce front-back variation but will also introduce some amount of left-right fluctuation.  In almost all ovens, the center will be hotter than the corners.
Overview of the modifications
To convert the toaster oven to a reflow oven, here are the steps we'll be taking:
Step 1: Open it up
Disclaimer: Converting an oven to a reflow oven will probably invalidate the manufacturer's warranty on the oven.  Ovens use high voltage electricity and potentially lethal electric currents.  Whizoo (and Peter Easton) cannot be held liable or responsible or will accept any type of liability in any event, in case of injury or even death by building and/or using or misuse of this information posted on this web site. By accessing, reading, and/or printing the articles presented here you agree to be solely responsible as stated in the above disclaimer and exempt Whizoo and/or Peter Easton from any criminal and/or liability suit. Safety is a primary concern when working with high voltage circuits and high-temperature ovens. Play it safe!Tip: click on any photo to see the high-resolution version.
Tip: take a look at the Hall of Fame to get inspiration from others.
Tip: think about ordering an aluminum tray if you haven't already done so.
This should be pretty easy.  Make sure the oven is UNPLUGGED and keep track of where all the screws go.
Tip: now is a good time to identify sharp edges in and around the oven.  Place tape over them so you don't cut your hands as you work on the oven. Or don't - because the best projects are the ones that involve blood.
Step 2: Remove the old controller
To keep things safe and to make space for the new controls you should remove all unnecessary parts from the oven.  Identify the wiring used by the elements; you'll need to connect them to the SSR's in step 12.  When cutting wires, leave them as long as possible; they need to be able to reach your SSR's.  Save any wire from the oven.  It is high-temperature wire that could come in handy later.  The top control is removed because that is where the wires to the controller will be fed through.
Step 3: Mount the relays
ControLeo2 supports both mechanical and solid-state relays (SSR).  If you don't plan to use your oven much, or if you don't have 2 pennies to rub together you can use mechanical relays.  The contacts in mechanical relays do wear out over time.  SSR's have no moving parts so they aren't affected by physical shock, vibration or changes in altitude.  They operate silently and produce little electrical interference.  They don't produce any arc so they are suitable for hazardous environments.  We only use SSR's when building reflow ovens.When choosing SSR's keep in mind the environment they will operate in (it is hot and the heat sink is relatively small).  You should derate the SSR to allow for this.  In the case of an SSR controlling power to two 375W elements, the current will be 2 * 375W / 110V = 7 Amps.  Choose a 20A SSR to be safe.
The relays are mounted to a thermally conductive piece of metal.  Copper has excellent thermal properties, and aluminum is pretty good too.  That's why these metals are used as heat sinks and inside computers.  Steel is actually not that good.  Each SSR can handle 5A without needing a heat sink, and these are getting less than 7A each.  When doing a reflow, the SSR's and aluminum plate get slightly warm.
The SSR's in this guide are mounted on a 6" x 6" aluminum sheet that is 1/16" thick.  Figure out how this sheet will be mounted in the oven, and how the relays will be mounted on the sheet.  Keep the sheet away from the oven wall, and as low as possible (heat rises).  Place a thermally conductive pad or paste between the SSR's and the aluminum sheet.  Rivets are great for keeping things together but you can use nuts and bolts too.  Make sure nothing can come loose because the last thing you need is anything rolling around near high-voltage wiring!
Tip: make sure all the oven wires will be able reach the SSR's.
Tip: remove burrs on any holes wires will be fed through.  A countersink bit is good for this.
Tip: (convection ovens) if the aluminum sheet is smaller than used here, or the relays are carrying more current then consider adding active (cooling fan) and passive (heat sink) cooling to ensure the SSR's don't overheat.
Step 4: Prepare the enclosure
Figure out where ControLeo2 will be mounted.  Make sure the oven door can still open (don't forget about the servo bracket), and the oven can be put back together!  Drill a hole through the ABS plastic enclosure of sufficient size for the wiring.  ControLeo2 has a USB port that is used for firmware upgrades and temperature logging.  Getting to this USB port once everything is assembled is very difficult and you run the risk of bending wires past their breaking point.  It might make sense to make a hole for the USB port too - just enlarge the pilot hole behind the sticker.Tip: having access to the USB port is necessary to update the firmware or logging temperatures to a PC.  The hole doesn't look bad with a piece of black electrical tape over it.  It is a very good idea to make the hole, and then square it off so that it easily accepts a USB cable.
Step 5: Drill holes
  The boost element will be held up by 3/16" x 1-1/2" eye bolts.  The ends of the element don't get nearly as hot as the middle, so they eye bolts should be located near the ends of the element.You'll be making 12 holes in this stage:
  • A hole for the wires from the boost element into the control chamber (3/16").
  • A hole for the wires from the thermocouple probe into the control chamber (3/16").
  • 2 holes for the eye bolts used to support the boost element (3/16").
  • 2 holes for the zip tie that will hold the power supply (5/32").
  • 2 holes to hold the SSR plate in place (9/64").
  • 4 mounting holes for the enclosure (1/8" and 1/16").
Firmly attach the SSR plate to the oven.  Avoid using the wall to the oven as a mount point.  Take care to ensure no metal filings are left behind!  When you're done, make sure the wires for the thermocouple and the boost element fit through their respective holes
Tip: use a countersink bit to deburr the holes that wires go through!
Step 6: Insulate the oven
Warning: this is probably the most difficult part of the build!For the most part, the oven is insulated using a 2" x 18' roll of Reflect-A-Gold.  This insulation is capable of handling continual temperatures up to 450°C (850°F).  The goal of this insulation is to close the air gaps where heat escapes and to reduce the thermal mass of the oven by reducing the amount of heat lost to the steel chassis.  If you have it, you can use high-temperature silicone glue to block the air gaps.
Make sure to use genuine Reflect-A-Gold, not some fake stuff available from eBay or AliExpress.  The insulating properties are very similar but the adhesive on this tape doesn't stand up to the high reflow temperatures as can be seen here and here.
Boom Mat is used below the bottom element.  This insulation can handle continual temperatures up to 950°C (1750°F).  The bottom elements are on most of the time, and the aluminum helps to wick away the heat from the center of the oven and spread it evenly about the bottom.  It is tempting to put Boom Mat above the top element too.  Unfortunately the adhesive will fail at high temperatures and the Boom Mat will fall onto the top element and catch fire. Yes, this is what happens!
Given the cost of the insulation, we focus on areas where the greatest benefit is obtained.  Look for seams where hot air can escape.  The top of the oven, the door, the wall to the control chamber and the area around the heating elements are the most important areas to cover.  A peep hole in the door allows you to monitor the progress of the reflow.
Tip: use a bungee (elasticated cord) to hold the oven door open while you place the insulation.
Keep a small piece of Reflect-A-Gold to insulate the around around the thermocouple (next step).  To place the Boom Mat, peel away the plastic backing on the far edge and place it in the oven.  When you're happy with the location, press the exposed edge down and remove the rest of the backing.
Tip: you can use Nomex high-temperature gasket to reduce the air gap around the oven door.
Step 7: Install the boost element
The boost element is a 110V 350W resistive heating element normally used for heating molds. The boost element must fit tightly inside the eye bolt.  It may be necessary to enlarge or reduce the size of the eye hole.  Drill through the Boom Mat using the holes you made in the oven earlier as a guide.  Put the element through the eye bolts and then put the bolts through the holes.  Wrap some Reflect-A-Gold around the wires where they go through the oven wall to protect them.  Make sure everything is bolted down securely.Tip: having only one eye bolt fit tightly on the boost element makes installation easier.
Step 8: Install the thermocouple
The "k-type" thermocouple probe is fiberglass insulated and can measure up to 550°C.  This particular probe is used because it has low-mass tip so it responds very quickly to changes in temperature. The thermocouple should measure the temperature experienced by the solder so the best way to mount the thermocouple is to use aluminum tape and tape it to the board being reflowed.  This is a really good method in theory, but in practice it falls short.  It is difficult to place the probe on the PCB (even a sacrificial PCB) and get consistent results.  The thermocouple could be over a via, or there may be a tiny air gap between it and the PCB.  There's also the ever-present danger of bumping components when trying to place the thermocouple.A better method is to recognize that the thermal mass of the oven is largely unchanged between runs.  It is best to place the thermocouple in a location that should reflect the board temperature and is away from any direct heat from the heating elements.  We have built ovens and reflowed boards using both placement methods and we recommend this method without reservation.
Make sure the thermocouple probe is securely mounted and the hole to the control chamber is sealed.
Step 9: Install the power supply
We've decided to mount the 5V power supply for ControLeo2 inside the oven.  Add wires (not supplied) to the power supply to make it easier to connect once inside the oven.  Cut the end off the power cord and identify the positive and negative wires using a multimeter.  Resist the temptation to tin the wires - this is not recommended.  You can use ferrules if you like.The control chamber (with the relays and power supply) gets warm during a reflow - but nowhere near hot enough to melt wire insulation.  While you must use high-temperature wire inside the oven and for any wires touching the oven walls, ordinary wire can be used as shown in the photos.
Tip: after exposing the wires in the power supply, it is an excellent idea to connect it to ControLeo2 to make sure things work.  Adjust the LCD contrast if necessary.  Power from the USB port goes through a diode, so the LCD contrast will differ between USB power and the 5V power supply connected using the screw terminals.
Tip: now might be a good time to update the firmware running on ControLeo2.  The latest version is v2.0.
Tip: now is a good time to put button covers (colored plastic spacers) on ControLeo2.  This is shown in step 16, but doing it now is easier.
Tip: instead of soldering wires onto the power supply prongs, you can use female spade crimp connectors.
Attach the enclosure to the oven now.
Step 10: Do the high-voltage wiring
It is important to get your high-voltage wiring right!  If your oven is 220V your elements may be wired in series, not parallel.  If you are not 100% confident dealing with electricity, please consult an electrician.  You can also ask questions using the feedback form below.The "hot" wire goes to each of the SSR's and to the 5V power supply.  The "neutral" wire goes to one end of each heating element and also goes to the 5V power supply.  The other end of each element is also wired to a SSR.  Use zip ties to keep the wiring neat.
Tip: label the SSR's so that you know which SSR controls which heating element.
Step 11: Feed the wires out of the oven
The wires coming from the oven are:
  • Wire from the 5V power supply.
  • Wire for 3 SSR's.  The relays have common positive, so we use a 4-conductor wire for 3 SSR's.  The wire needed won't be carrying much current (max 10ma @ 5V per SSR) so even something as thin as a USB cable can be used.  Mechanical relays need around 50ma @ 5V each, so again the wire doesn't need to be a heavy gauge.
  • The thermocouple wires.
Feed the wires through the grommet and through the braided sleeving.  To keep things neat and secure, we use 10" of 1/4" braided sleeving.
Step 12: Mount the door servo
The servo is mounted without the rubber insulators; they really aren't needed here.  Feed the servo wire, and the oven wires through the enclosure.  Add a zip tie for strain relief - but first make sure that you have enough length in the wires to reach the screw terminals on ControLeo2!
Step 13: Add servo hardware to ControLeo2
Get out your soldering iron!  Some components have to be soldered to the board to support the servo
  • A 3-pin header is soldered to GND, 5V and D3.
  • Most servos will make a sudden sharp movement when you first apply power.  A 10K pull-up resistor will stop that behavior.  The resistor is placed between 5V and D3.
  • When the servo moves, the stall current can lower the voltage going to the board and cause a brown-out condition.  The 220uF capacitor is needed to prevent this.  Connect it between 5V and GND.  Yes, just like the photo shows. No, it isn't connected to 3.3V.  Yes, we know it looks like it is - but it isn't.
Tip: the capacitor is polarized, so make sure you solder the negative side to GND!
Step 14: Wire up ControLeo2
There is a definite order to attaching the wires to ControLeo2.  Avoid repeatedly bending wires past their breaking point.  At each step a test can be performed to ensure correct operation.Attach the spacers to the board.  You can use tape so the spacers stay on the screws - or just use pliers and squeeze the middle of the spacer before placing the spacer on the screw.  Strip all the wires so that they are ready to be inserted into the screw terminals.  Unscrew the screws in the screw terminals.
Attach the 5V power wires.
Test 1 - check 5V power
Make sure your high-voltage wiring is safe, then plug in the oven.  ControLeo2 should receive power and start up.  If you didn't do this in step 9, this is a good time to adjust the contrast on the LCD display.
>>> Unplug the oven when you're done. <<<<
Attach the thermocouple wires.  Green is "-" and red is "+".  If you're color-blind just guess!  No harm will occur if the thermocouple leads are reversed.
Test 2 - Check thermocouple operation
Make sure your high-voltage wiring is safe, then plug in the oven.  ControLeo2 should receive power and display the temperature.  Open the oven door and hold the tip of the thermocouple.  The temperature should increase - unless you have icy hands.  If the direction of temperature change isn't correct then reverse the red and green wires.
Connect the servo and the low-voltage SSR wires.
  • D4 = black (bottom element)
  • D5 = green (top element)
  • "+" = red (common positive)
  • D6 = white (boost element)
  • D7 = unused
Screw ControLeo2 into the enclosure (don't put the cover on yet in case you need to access the wiring again).  Feed the braided sleeving into the control chamber.
Tip: you might want to take a photo of your wiring, in case you need to refer back to it.
Step 15: Finish the low-voltage wiring
Keep the low-voltage wiring as far as possible from the high-voltage wires.  Take special care of the thermocouple wire; it is carrying millivolts and close proximity to wires carrying large loads can interfere with temperature readings.The wires are connected as follows:
  • red - connected to all 3 SSR's.
  • white - connected to the boost SSR.
  • black - connected to the bottom SSR.
  • green - connected to the top SSR.
Test 3 - Check SSR operation
Make sure your high-voltage wiring is safe, then plug in the oven.  ControLeo2 should receive power and show a test menu.  You can watch this short video to see how the menu system works.  Pressing the bottom button will cycle through each SSR.  Watch the SSR and make sure the LED on it lights up at the right time.  Expect to hear some buzzing from the elements as they start to heat up.
Step 16: Close the oven
Remove the plastic film protecting the LCD display.  Put colored spacers on the buttons - this gives them a nice look and feel!  Put the cover on the enclosure and close up the oven.Tip: before closing the oven make a last check for loose nuts, bolts, screws, wires and metal shavings.  Use zip ties to keep wires in place.  Make sure the chassis screws you're about to insert don't pierce any work you've just done.
Step 17: Finish the door servo
Turn on the oven, and navigate through the menu to the door open position.  It should show 90° - this is the mid-point in the servo movement.  If it doesn't show 90° then press the top button until it does.  Attach the servo arm to the servo disc using four M3 screws.  Mount the arm to the servo in what you think will be the mid-point of it's movement.
Take a 3" x 1/2" piece of aluminum and drill 2 holes in it using a 1/8" drill bit.  Give it a 90° bend as shown in the photos.  Drill 2 pilot holes in the oven handle using a small 1/16" or 5/64" drill bit.  Attach the aluminum to the handle.  Once you've done this, use ControLeo2's menu to adjust the open and closed positions for the servo.  The oven door should open around 1". That is enough to provide sufficient cooling after the reflow.
The door servo is always moved to the closed position when the oven powers up.  The door will be opened slowly soon after the maximum temperature is reached, and closed again when the oven cools to 50°C.
Step 18: Install the PCB tray
The PCB tray is the single most important part of a reflow oven.  Good heat distribution is paramount to a successful reflow and the tray the most important part of the equation.  The trays that typically come with ovens are made from steel (if it is magnetic it is steel), which you already know is not good.  Using the rack is like going to the beach wearing a bikini and expecting a "no-lines" tan!For this oven we're using a custom cut 1/32" thick 8"x10-5/8" sheet of 5052 aluminum (get them here.  Todd can also do custom trays) that exactly fits our oven.  1/32" is the right thickness; any thicker and we're just adding thermal mass and any thinner it will lose rigidity. Any metal with a good thermal conductivity will work.
Another good approach - especially for convection ovens - is to use the rack that came with the oven but remove most of the wires to reduce thermal mass.  A thin aluminum or copper sheet can be placed directly on top of this modified rack.  Convection ovens will need good airflow around the metal sheet, so make holes around the edges if necessary.
Step 19: Configure ControLeo2
Navigate to the Reflow Wizard setup menu.  You can watch this short video to see how the menu system works.Configure the outputs D4, D5, D6 and D7 as you've wired them.  You can also set the maximum temperature.  The default maximum temperature of 240°C is good for lead-free reflow.  If you are using leaded solder then change this to the value recommended by your solder paste datasheet.  Pressing the top button repeatedly will increase the temperature up to 280°C, and then it rolls around to 175°C.  The reflow curve is automatically adjusted based on the maximum temperature.
Step 20: Let the Reflow Wizard learn your oven
Tip: if you haven't already, now might be a good time to update the firmware running on ControLeo2.  The latest firmware is v2.0.This step is going to take some time.  If you've built your oven exactly as described above it could take 1 cycle to verify that your oven conforms to the J-STD-020 standard, but the odds are it will take a few cycles (perhaps 10) to get out of "learning" mode.
Tip: the tray MUST be in the oven during learning mode!  The thermal mass must as close to normal reflows as possible.
  • You want to run this test outside, or in a well ventilated area.  There will be some fumes - this is normal.
  • Place the PCB tray in the oven, but don't place any boards on it.
  • Close the oven door.
  • Start a reflow.  The LCD screen will tell you that learning mode is enabled.
  • If the temperature rise is too fast or too slow, the learning run will be aborted.  A message will be displayed on the LCD screen to this effect.
  • The Reflow Wizard will make some adjustments to its settings.  Those settings are stored in non-volatile RAM (EEPROM).
  • Open the oven door and let the oven cool to room temperature.
  • Seriously, let it cool down.  Wait 20 to 30 minutes.
  • Go back to step #3.
Once the temperature rise meets J-STD-020 the Reflow Wizard will leave learning mode.  From this point on the Reflow Wizard will continuously monitor every reflow and will make very small adjustments if needed.If one of the outputs is reconfigured (for example, if D4 is changed from "Bottom" to "Top") or the maximum temperature is changed by more than 5°C then the Reflow Wizard will re-enter learning mode.
If you want to monitor the Reflow Wizard's performance, you can install the Arduino software on your PC and monitor the status messages using the Arduino Serial Monitor.
If you want to understand how the Reflow Wizard works, you can look at the source code here.
Step 21: Run some test cycles
Use scrap PCB's and components you no longer need.  Place some solder paste on the boards and some components.  A simple test is the "yellow capacitor" test as documented in a Kickstarter update.  A better method is to use Temperature Test Labels, as shown here.Place boards in a 3x3 grid on the oven tray.  This will help you determine if you have any hot or cold spots in your oven.  The corners typically run a little cooler and the center a bit hotter. Do a reflow and examine each board in turn.  Was there sufficient heat for the solder reflow to happen, but not too much that the boards warped or components were burned?
If needed, the maximum temperature setting can be adjusted up or down depending on your results.  Keep in mind that the error in the MAX31855 is 2°C and the thermocouple probe is around 3°C.
If not using the door servo, when instructed to open the oven door open it an inch or two.  Be careful not to let the cool down rate exceed 6°C/second; the optimal rate is 2°C/second.  Once the oven cools to 100°C the boards can be removed, but you can leave them in longer so you don't need gloves to handle them.  The oven must be below 50°C to be able to start a reflow.
Step 22: Final thoughts
Boards and paste
OSHPark produces excellent quality boards and delivers them quickly.  For most prototype boards, having a stencil reduces assembly time and improves soldering so much less rework is needed. We love stainless steel stencils, and often order boards and stencils from Smart Prototyping in China.  Their quality is not as good (around 1 in 250 boards has a problem) but overall we're very happy to recommend them.We personally use Chip Quik SAC305 lead-free paste and we're happy with the results.  From feedback we've received, any no-clean lead-free paste appears to be as good as any other.  Paste freshness is important; the flux in the paste will degrade over time.  Keep it refridgerated per the manufacturer's instructions.  Fine-pitch components and especially BGA's will need the freshest and best quality paste.  If you're doing a low-frequency design with large component pads you can probably use cheaper, older paste.
Double-sided boards
ControLeo2 is not well designed to handle two different solder pastes, with their different reflow profiles.  However, there are techniques to make this work:
1. Use epoxy to hold the larger components on the 1st side in place.  Surface tension will keep the smaller ones in place when reflowing the 2nd side.
2. Reflow the more complex side of the board and hand-solder the 2nd side.
3. Some users save the learnt settings for each type of paste, then reflash ControLeo2 before each reflow.  This is cumbersome though.
The source code for ControLeo2 is open-source, so if you'd like to improve this we'd love to share your efforts with our users!
You're done!  Enjoy your new reflow oven.
If you have photos or video you'd like to share on our Hall of Fame then please let us know.  If there is anything we can do to improve this guide let us know that too.
沙发
发表于 2017-2-19 15:36:47 | 只看该作者
谢谢楼主分享
板凳
发表于 2017-2-21 08:59:54 | 只看该作者
有没有增强版监控
地板
发表于 2017-2-21 09:07:16 | 只看该作者
谢谢分享,学习一下
5#
发表于 2017-2-21 09:08:28 | 只看该作者
谢谢分享,学习一下
GMT+8, 2026-4-6 00:39 , 耗时 0.194075 秒, 20 个查询请求 , Gzip 开启.
