查看: 6949|回复: 5
Reflow Toaster Controller
发表于 2012-1-14 15:00:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Description:
The Reflow Toaster controller from Spark Fun Electronics. This board was specifically developed to control a toaster oven, hot plate, reflow oven, or other high power device. The unit comes as a kitwith all the needed components for a fully independent system. Runs on a PIC 16F88 with boot loader pre-loaded (no programmer required).
No system code is provided. We get you the hardware, you get the thrill of creating the control system yourself!
We do provide example C code (CC5X compilable) that demonstrates control of the LCD, reads the buttons, displays the temperature on the LCD, debugging output via RS232 to Screamer, and toggles the power relay. Relay can be mounted on PCB but we found that it is best to keep the relay as close to oven as possible running control wires back to the PCB. More information can be found in the Reflow Toaster tutorial.
As to be expected - we do not recommend this kit to anyone who is not familiar with electronics. The kit is entirely through-hole devices. However, when using the high-power relay, the user will need to splice into the AC power cable of the device you are attempting to control. This can be extremely dangerous causing death or dismemberment.
We cannot be held responsible for any damages caused by this kit - use at your own risk.
Features:
  • PIC 16F88 running at 8MHz
  • Thermocouple readings from -270 to +1372C
  • High power relay controls up to 220VAC @ 30A
  • 16x2 LCD STN with Backlight (looks great!)
  • Three buttons for menu control
  • Status LED
Kits Includes:
  • Bare PCB
  • High power SPST-NO Relay
  • 30" Type-K Thermocouple
  • 16F88 Preloaded with Bloader
  • AD595AQ IC
  • 16x2 LCD with Backlight
  • MAX232
  • Wall Power Supply
  • Small parts (caps, sockets, BJTs, connectors, etc)
Documents:
收藏收藏1 分享分享 支持支持 反对反对
沙发
发表于 2012-7-30 11:34:15 | 只看该作者
板凳
发表于 2012-8-22 03:16:58 | 只看该作者
说的不错!
地板
发表于 2012-9-16 09:58:28 | 只看该作者
控制器做的不错,就是第三项Excellent Article by Kit RyanPDF读不了。
5#
 楼主| 发表于 2012-9-16 22:35:01 | 只看该作者
1、文件下载不全,请下载本地后再看
2、换个pdf查看工具试试
6#
发表于 2015-10-28 22:13:30 | 只看该作者
这个很好,学习学习
GMT+8, 2026-4-6 00:35 , 耗时 0.123641 秒, 21 个查询请求 , Gzip 开启.
