查看: 4562|回复: 1
Reflow oven with PID control
发表于 2013-9-11 07:44:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原文:
Hi guys ,
i' currently building a reflow oven with PID control with PICAXE 28X1.I'm using a standard pizza oven and using a relay to control the main power switch.
Since i'm still a newbie in regard of PID control and PWM, i have intergrate the PID control from greencardigan project 'coffee maker' into the source code of my project.
The oven should operate with this parameters
1.heat to 150°C and maintain for 40s
2.heat to 190°C and maintain for 10s
3.heat to 245°C and maintain for 10s
4. Cool down to room tempereature
the code is as followed:
  1. symbol Kp = 1000
  2. symbol Ki = 20
  3. symbol Kd = 10
  4. symbol dt = 1
  5. symbol set_temp =w0
  6. symbol set_time =b0
  7. symbol sensor = 1
  8. symbol cur_temp = w1
  9. symbol cur_time=b1
  10. symbol oven = 7
  11. symbol led_hot =5
  12. symbol led_hold =4
  13. symbol err = b2
  14. symbol pre_temp =b3
  15. symbol INT_MAX = 1000
  16. symbol PRO_MAX = 15000
  17. symbol DER_MAX = 5000
  18. symbol PID_MAX = 52768
  19. symbol PID_MIN = 12768
  20. symbol PID = w2
  21. symbol x=b4
  22. symbol input_button1= pinc.1
  23. '#########################################################################################
  24. INIT:
  25. set_temp =0
  26. set_time =0
  27. PID = 49000
  28. '#########################################################################################
  29. Main:
  30. do
  31. low oven
  32. low led_hot
  33. low led_hold
  34. if input_button1 = 0 then        'Waits in this loop until button1 is pressed
  35.   exit
  36. endif
  37.
  38. gosub get_temp
  39. gosub Phase_1
  40. gosub get_temp
  41. gosub Phase_2
  42. gosub get_temp
  43. gosub Phase_3
  44. gosub get_temp
  45. gosub Phase_4
  46. low oven
  47. loop
  48. goto main
  49. '#########################################################################################
  50. get_temp:        'Reads thermocouple
  51. readadc10 sensor, cur_temp
  52. return
  53. '#########################################################################################
  54. Phase_1:
  55. set_temp =123 'set temperate at 150°C
  56. set_time =40  'hold 150°C for 40s
  57. if cur_temp < set_temp then
  58. gosub get_temp
  59.   high led_hot
  60.   gosub PID_calc
  61.   gosub PID_control
  62. endif
  63. low led_hot
  64. for  cur_time=1 to set_time
  65. gosub get_temp
  66.   high led_hold
  67.   gosub PID_calc
  68.   gosub PID_control
  69.   pause 1000
  70. next cur_time
  71. low led_hold
  72. return
  73. '#########################################################################################
  74. Phase_2:
  75. set_temp =156 'set temperate at 190°C
  76. set_time =10  'hold 190°C for 10s
  77. if cur_temp < set_temp then
  78. gosub get_temp
  79.   high led_hot
  80.   gosub PID_calc
  81.   gosub PID_control
  82. endif
  83. low led_hot
  84. for  cur_time=1 to set_time
  85. gosub get_temp
  86.   high led_hold
  87.   gosub PID_calc
  88.   gosub PID_control
  89.   pause 1000
  90. next cur_time
  91. low led_hold
  92. return
  93. '#########################################################################################
  94. Phase_3:
  95. set_temp =201 'set temperate at 245°C
  96. set_time =10  'hold 245°C for 10s
  97. if cur_temp < set_temp then
  98. gosub get_temp
  99.   high led_hot
  100.   gosub PID_calc
  101.   gosub PID_control
  102. endif
  103. low led_hot
  104. for  cur_time=1 to set_time
  105. gosub get_temp
  106.   high led_hold
  107.   gosub PID_calc
  108.   gosub PID_control
  109.   pause 1000
  110. next cur_time
  111. low led_hold
  112. return
  113. '#########################################################################################
  114. Phase_4:
  115. set_temp =20 'set temperate at 25°C
  116. set_time =10  'go to 25°C to cool down
  117. if cur_temp => set_temp then
  118. gosub get_temp
  119.   high led_hot
  120.   gosub PID_calc
  121.   gosub PID_control
  122. endif
  123. low led_hot
  124. return
  125. '#########################################################################################
  126. PID_calc:
  127. gosub get_temp
  128. if PID > 49000 then
  129.         PID = 49000
  130. else
  131.         PID = PID
  132. endif
  133. if cur_temp <= set_temp then        'for negative errors
  134.
  135.         err = set_temp - cur_temp        max 65         'error
  136.
  137.         w3 = Ki * err * dt max INT_MAX        'INTEGRAL..........................
  138.         PID = PID + w3 max PID_MAX
  139.
  140.         w3 = Kp * err max PRO_MAX        'PROPORTIONAL......................
  141.         PID = PID + w3 max PID_MAX        'Int + Pro
  142.
  143. else 'for positive errors
  144.         err = cur_temp - set_temp        max 65        'error
  145.
  146.         w3 = Ki * err * dt max INT_MAX        'INTEGRAL.........................
  147.         PID = PID - w3 min PID_MIN
  148.
  149.         w3 = Kp * err max PRO_MAX        'PROPORTIONAL....................
  150.         PID = PID - w3 min PID_MIN        'Int + Pro
  151.
  152. endif
  153. 'if cur_temp > err then 'temp increasing
  154.         'w3 = cur_temp - err
  155.         'w3 = w3 * Kd max DER_MAX        'DERIVATIVE ......................
  156.         'PID = PID - w3 min PID_MIN        'int + pro + der
  157. 'elseif cur_temp < err then 'temp decreasing
  158.         'w3 = err - cur_temp
  159.         'w3 = w3 * Kd max DER_MAX        'DERIVATIVE ......................
  160.         'PID = PID + w3 max PID_MAX        'int + pro + der
  161. 'else
  162.         'w3 = 0 'no derivative part
  163. 'endif
  164. 'pre_temp= cur_temp
  165. return
  166. '#########################################################################################
  167. PID_control:
  168. for x = 1 to 1000                                'Manual PWM with 1 second period (adjust pause at end of main routine to get 1 sec period)
  169.         if x > PID then
  170.                 low oven
  171.         else
  172.                 high oven
  173.         endif
  174.
  175.         pause 6
  176. next x
  177. pause 54                                        'Adjust to get timing right on PID mode (1 sec PWM period)
  178. return
  179. '#########################################################################################
复制代码
The PID controller seems to be not functioning. The oven will heat to 160°C and the picaxe will exit the program.
Can someone spot any mistake?
Thanks
grimmjaws
收藏收藏1 分享分享 支持支持 反对反对
沙发
发表于 2015-10-22 21:52:07 | 只看该作者
感谢楼主提供这么好的东东
GMT+8, 2026-4-6 00:45 , 耗时 0.116948 秒, 21 个查询请求 , Gzip 开启.
