楼主: 半步颠
总结TL866CS升级TL866A,献给比我还菜的菜鸟
发表于 2018-10-31 00:24:45 | 只看该作者
大家不升级到了,会变砖的。不要升级了。
22#
发表于 2019-1-22 21:51:15 | 只看该作者
393129830 发表于 2018-10-31 00:24
大家不升级到了,会变砖的。不要升级了。
请用新版本V2.5,更新crc
TL866.zip (1.06 MB, 下载次数: 491)
1. Browse for update.dat file (any version is good including the new 6.80, 6.81 and 6.82)
2.Select the firmware dumper and click reflash.
3.After reflash click the advanced button
4.Now pay attention: if the copy protection checkbox is unchecked please check this and click write button.
If the copy protection checkbox is checked leave it alone.
This is important if you leave the copy protect bit unchecked then the new firmware will disable the bootmode, so beware!
5.Serial number and device code section.
Just click the write button in the serial number section. This will rewrite the same serial with the correct checksum.
This was a flaw in my reencrypted serial. A single byte checksum was wrong and the autoelectric discovered this after five years! good. I like this.
6.Close the advanced window, check the TL866A firmware and click reflash again.
强制进入bootmode方法
if the programmer is bricked. you can add a resistor(about 240 ohm) as the follow picture. and install old version software , then reflash firmware. then remove this resistor.
23#
发表于 2019-1-31 21:35:53 | 只看该作者
TL866_ICSP
24#
发表于 2019-2-20 10:29:27 | 只看该作者
不错,正需要!!!
25#
发表于 2019-3-7 16:00:44 | 只看该作者
xiaodaishu 发表于 2019-1-22 21:51
请用新版本V2.5,更新crc
1. Browse for update.dat file (any version is good including the new 6. ...
感谢分享,
26#
发表于 2019-3-8 22:08:00 | 只看该作者
虽没有这个,也感谢LZ分享。
28#
发表于 2020-1-10 20:26:04 | 只看该作者
回贴是美德,感谢分享!
29#
发表于 2020-1-20 11:59:06 来自手机 | 只看该作者
感谢分享,正好升级一下我的tl866CS
30#
发表于 2020-1-23 00:29:49 来自手机 | 只看该作者
今天没事升级成功了,用的2.5版本
GMT+8, 2024-6-26 11:08 , 耗时 0.105929 秒, 19 个查询请求 , Gzip 开启.
