查看: 9173|回复: 6
PAL Device Reader(pal芯片读出工具)
发表于 2014-10-4 15:44:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
pal芯片读出工具,看说明是可以读出pal类pld芯片的工具,通过软件可以将读出的文件转成jed格式,是不是很牛啊
工作原来是该分析输入输出时序来获取的
可惜只有rev2版的制作资料,rev3的软件暂时没找到
rev1的电路板
rev2的
这是就是rev3的
下面这些就是自作资料了,只提供pcb图,没有原理图,该可以想法转过来吧
pd-070908.zip (369.31 KB, 下载次数: 42)
rev2改rev3
Revision 3 Fix
    This modification allows the PIC to inhibit switching until enumeration    has completed. Please read all of the steps first before attemping    the modification.
1.)    Solder side:    Cut the following trace going to pin 6 of the PIC chip socket.    Use a multimeter to verify the connection has been severed.
2.)    Solder side:    Solder a wire between pin 16 of the 40-pin USB module socket and    pin 6 of the 8-pin PIC socket.
3.)    Component side:    Remove resistor R2.    We will reuse it in the next step, or you can simply get a new    4.7K ohm, 1/8 watt resistor to replace it.
4.)    Solder side:    Solder one lead of resistor R2 to the circled point.
5.)    Solder side:    Solder the other lead to any +5V point. This includes the area    that is circled or anywhere along the vertical track that is boxed.
   Be extra careful that the leads of the resistor do not    touch anything else.
    You could place electrical tape underneath the resistor or use    heat shrink tubing or an insulating sleeve on the leads to keep them from touching other    exposed tracks underneath it.
6.)    Reprogram the PIC12F675 with the new firmware (main.hex):
rev3的固件
pic-rev3a.zip (562 Bytes, 下载次数: 16)
收藏收藏3 分享分享 支持支持 反对反对
沙发
发表于 2015-4-25 04:18:37 | 只看该作者
thank you sir this is wonderfull
板凳
发表于 2015-4-25 04:18:57 | 只看该作者
thanks you sir you are good
地板
发表于 2015-6-14 01:22:43 | 只看该作者
I'm insterested to
5#
发表于 2016-5-28 09:54:34 | 只看该作者
不错,是我需要的
6#
发表于 2016-8-27 20:23:25 | 只看该作者
HOW CAN I DOWNLOAD THE LINKS?
Best regards
JOSÉ GONÇALVES
点评
http://matthieu.benoit.free.fr/qb45/analyzer/pd-070908/doc/  详情 回复 发表于 2026-7-17 03:15
7#
发表于 2026-7-17 03:15:18 | 只看该作者
ramparts1978@sa 发表于 2016-8-27 20:23
**** 作者被禁止或删除 内容自动屏蔽 ****
http://www.ourdreambox.com/ubbth ... lat&Number=3437
GMT+8, 2026-11-1 03:21 , 耗时 0.505797 秒, 23 个查询请求 , Gzip 开启.
