查看: 8157|回复: 2
TIAO Black Flash USB+ Universal Flash Programmer
发表于 2014-10-14 20:44:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
从图上可以看出,这是个混合产品,通过一个usb hub芯片gl850g扩展出4个usb,两个用于usb座,一个用于pl2303h扩展出串口,一个接到atmega32u2实现spi或者jtag,这里的转换是通过模拟的usb1.1实现的,基本就是个整合的产品。
pcb图
  Serial (TTL Level) header The TTL level COM port header.
Pin #
Description
1 Tx
2 Rx
3 DTR
4 DSR
5 RTS
6 DCD
7 RI
8 CTS
9 +3.3V
10 +5V (USB Power)
11, 12 GND
  Application Status LED Indicator Indicates the current application status of the flash programmer.
  Output Voltage Selector Move the jumper to 3.3V if the target device support 3.3v.  Move the jumper to 5v if the target device supports 5v.
  Reset Button Resets the device or force the programmer to enter the bootloader mode.
  Mode Change Switch Application mode change switch.
The functionality of this programmer differs depending on the type of firmware programmed into it.
Change to bootloader mode (1 at ON position, 2 away from ON position) (also known as the DFU mode) to perform a firmware update over USB.
Change to application mode (both 1 and 2 at ON position) to execute the firmware loaded into the programmer.
In Application Mode, pressing the reset button will only perform a USB reset. In Bootloader Mode, it will reset the device but when the device automatically reconnects, it will start in the DFU mode, allowing the software to load new AVR firmware.
  Flash Programmer Pin Header The pinout of the flash programmer depends on the firmware loaded into the programmer.
JTAG Mode Pinout:
Pin #
Description
1 GND
2 TCK
3 GND
4 TMS
5 GND
6 TDO
7 GND
8 TDI
9 GND
10 TRST
SPI Mode Pinout:
Pin #
Description
1 GND
2 Vcc
3
4 SI
5
6 SO
7 RST
8 SCLK
9 PROG
10 CS
NAND Mode Pinout:
Pin #
Description
1 GND
2 Vcc
3 EJ
4 SI
5 XX
6 SO
7 KSK
8 SCLK
9
10 CS
源代码
FCUSB.RC15.330.SourceCode.zip (301.81 KB, 下载次数: 0)
win版软件
FCUSB.RC15.330.zip (9.17 MB, 下载次数: 0)
收藏收藏1 分享分享 支持支持 反对反对
沙发
发表于 2014-10-14 21:08:14 | 只看该作者
沙花,谢谢楼主分享。。
板凳
发表于 2016-5-31 14:31:08 | 只看该作者
好东西,感谢分享!!!
GMT+8, 2026-11-8 02:25 , 耗时 0.353224 秒, 24 个查询请求 , Gzip 开启.
