查看: 40319|回复: 26
nandpro3.0编程器
发表于 2013-10-13 08:39:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
和2.0e电路差不多
                SUPPORTED DEVICE INTERFACES
USB:
    LPC2148 Olimex USB header board.
    High performance 16MB/2Mins.
    LibUsb driver.
LPT:
    Parallel Printer Port, SPP mode.
    Low performance, 16MB/35mins (cpu dependant).
    Dlportio printer port driver.
XSVF:
    Subset device of USB.
    LPC2148 Olimex USB header board required.
    NOT for nand programming. This command line device type is for flashing
     .xsvf files to a Xilinx cpld.
POST:
    NOT for nand programming. This command line device type is for monitoring
     Post codes only.
The included .hex file supports both Nand SPI flash, Xilinx Programming,
and Post Monitor all at the same time.
The mode selected ie: Nand Flash/Xsvf/PostMon is determined by the command line.
Previous .hex files as well as the "pic" version of hardware will not work.
The Maximus "NANDFlasher" has an array of plated through holes to break out all
the extra LPC2148 gpio. This product can be flashed with the new ArmV3.hex file
for full comatibility with Nandpro. The wiring coordinates are included here for
those who have this device. The included .jpg file shows the connections
to flash this device with the Philips utility. An RS232 level shifter is also
required for this purpose.
The Team Executor "NAND-X" can also be flashed with the ArmV3.hex, however the
wiring connections may be difficult, and are not listed in this document.
Nandpro30.rar (1.99 MB, 下载次数: 57)
gui界面
NandProGui_v0.1.zip (531.22 KB, 下载次数: 34)
收藏收藏1 分享分享 支持支持1 反对反对
沙发
发表于 2015-6-15 12:21:22 | 只看该作者
我是拿来主义者,你做成成品我才有兴趣
板凳
发表于 2016-7-9 18:04:18 | 只看该作者
就等这个好东东
地板
发表于 2016-7-9 20:51:23 | 只看该作者
进来学习学习
5#
发表于 2016-7-11 16:48:23 | 只看该作者
东西很好!
我是打酱油的,赚点银子
6#
发表于 2016-9-1 21:05:20 | 只看该作者
开个板哈哈
7#
发表于 2016-11-25 18:18:11 | 只看该作者
WIN7 32位的能用不?UP1024一直闲着没法
8#
发表于 2017-1-5 14:18:18 | 只看该作者
回复看看内容
9#
发表于 2017-1-5 14:27:04 | 只看该作者
不够银子啊
10#
发表于 2017-1-5 14:27:31 | 只看该作者
接着赞银子
GMT+8, 2026-11-1 06:51 , 耗时 1.898356 秒, 22 个查询请求 , Gzip 开启.
