查看: 11050|回复: 9
CH341A 编程器使用说明(彩灯版v1.3)2019.9.16
发表于 2019-9-16 08:34:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CH341A 编程器使用说明
(彩灯版v1.3)2019.9.16
目 录
一、CH341A编程器简介..................................................................................................................2
二、编程器硬件部分.......................................................................................................................3
1、输出电压Vout....................................................................................................................3
2、spi输出..............................................................................................................................5
3、TTL输出............................................................................................................................6
4、彩灯说明.............................................................................................................................8
5、芯片放置.............................................................................................................................9
6、通用转接板.......................................................................................................................10
7、93xx芯片的放置方式图..................................................................................................11
8、45xx芯片的放置方式......................................................................................................12
9、qfn8转接板......................................................................................................................13
10、bga24转接板..................................................................................................................14
11、bga24 8mm*6mm 4*6球阵列翻盖座.........................................................................15
12、bga24 8mm*6mm 5*5球阵列翻盖座.........................................................................17
13、qfn8 8mm*6mm 翻盖座................................................................................................18
14、qfn8 6mm*5mm 翻盖座................................................................................................19
15、红外测码模块.................................................................................................................20
三、安装驱动.................................................................................................................................21
1、编程器驱动.......................................................................................................................21
2、TTL串口驱动..................................................................................................................21
四、编程器软件.............................................................................................................................22
1、AsProgrammer ..................................................................................................................22
2、ch341 usb编程器软件.....................................................................................................23
3、读写KB901x类芯片.......................................................................................................24
4、红外测码...........................................................................................................................25
五、常见问题及处理方法.............................................................................................................26
1、土豪金版的软件读写32M芯片不正常.........................................................................26
2、AsProgrammer不能读写microchip的93LC46A,93LC66A ......................................26
3、正在读写操作时,操作软件会出现读写状态灯灭掉...................................................26
4、AsProgrammer读出文件比艾科等专业编程器的小......................................................26
CH341A编程器v1.3使用说明.pdf (1.17 MB, 下载次数: 11)
沙发
发表于 2019-9-18 23:21:53 | 只看该作者
新人来报道,必须支持一下楼主的奉献
板凳
发表于 2019-9-19 19:54:07 | 只看该作者
支持下!就是有点小贵。希望物有所值!
地板
发表于 2019-9-23 06:18:03 | 只看该作者
谢谢,下载看看
5#
发表于 2019-9-28 01:02:46 | 只看该作者
大神!~~~看看~~~凑银子下资料~!~~郁闷~~~
7#
发表于 2021-2-12 22:08:05 | 只看该作者
这个很好,感谢楼主的好资料
8#
发表于 2021-3-20 13:42:26 | 只看该作者
谢谢啦,理解了
9#
发表于 2022-1-13 12:32:33 | 只看该作者
谢谢啦。理解了,赚足银两
10#
发表于 2024-1-22 13:25:33 | 只看该作者
挺好的  学习到了  希望后面多学习一下。
GMT+8, 2026-10-21 20:11 , 耗时 0.378759 秒, 21 个查询请求 , Gzip 开启.
