查看: 5701|回复: 2
CY8C22xxx/CY8C24xxx/CY8C27xxx ISSP协议
发表于 2014-10-7 22:24:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Table of Contents
Section 1. Introduction ................................................................................. 1
Section 2. Programming Flow ..................................................................... 3
2.1 Vectors ........................................................................................................................3
2.2 Clocking .......................................................................................................................4
2.3 Command Format ........................................................................................................4
Section 3. Initialize Target Procedure ......................................................... 5
3.1 Reset Mode .................................................................................................................6
3.2 Power-on Mode ...........................................................................................................6
Section 4. Verify Silicon ID Procedure ........................................................ 9
Section 5. Program Procedure .................................................................. 11
Section 6. Verify Procedure ....................................................................... 13
Section 7. Secure Procedure ..................................................................... 15
Section 8. Verify Checksum Procedure .................................................... 17
Section 9. Specifications and Definitions ................................................ 19
Section 10. Appendix A .............................................................................. 21
10.1 Programming Vectors for CY8C22xxx/CY8C24xxx/CY8C27xxx .............................21
Section 11. Appendix B .............................................................................. 25
11.1 IntelHex File Format for CY8C22xxx/CY8C24xxx/CY8C27xxx ...............................25
Index ............................................................................................................ 29
an2026A - ISSP for 27xxx.pdf (223.86 KB, 下载次数: 11)
板凳
发表于 2020-6-16 05:22:16 | 只看该作者
谢谢分享ISSP协议。
GMT+8, 2026-11-29 07:58 , 耗时 0.111912 秒, 20 个查询请求 , Gzip 开启.
