查看: 5639|回复: 2
FT2232H核心模块电路
发表于 2014-10-14 09:01:20 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
其实其他没有缓冲芯片的ft2232做的jtag都可以用该核心模块制作,只要对应引脚飞线就行,稍微见得麻烦点而已,其实这个反而方便,所有引脚都引出了
The FT2232H Mini modules can be used with blackmagic firmware or as FLOSS-JTAG device.
More Information can be found at the FT2232H Mini Module Serial Adapter page.
Important
Out of the box, there is NO power supply for the FT2232H because this can either done with USB or external 5V.
The pictures above show two different PCB versions. The suggested connections only apply to the right (latest) layout.
Connect: (for power supply over USB)
  • CN3 pin 1 to CN3 pin 3
  • CN2 pin group 1,3,5 to CN2 pin group 11,21 and to CN3 pin group 12,22
Pinout
UART
UsePinName
UART1 RX CN2-10ADBUS1
UART1 TX CN2-7ADBUS0
UART2 RX CN3-25BDBUS1
UART2 TX CN3-26BDBUS0
JTAG
UsePinName
JTAG1 TCK CN2-7ADBUS0
JTAG1 TDI CN2-10ADBUS1
JTAG1 TDO CN2-9ADBUS2
JTAG1 TMS CN2-12ADBUS3
JTAG2 TCK CN3-26BDBUS0
JTAG2 TDI CN3-25BDBUS1
JTAG2 TDO CN3-24BDBUS2
JTAG2 TMS CN3-23BDBUS3
Blackmagic firmwareFirst, get the VID/PID for your FT2232 device using 'lsusb'. Edit the file 'src/libftdi/platform.h' and change the VID/PID to match your hardware. Compile the application with the command:
make PROBE_HOST=libftdiFLOSS-JTAGWith the tool "FT_Prog" change the description the FT2232H to "FLOSS-JTAG".
识别为不同的设备主要就是那个93芯片内的vip/pid不同而已
ft2232hmodule.pdf (1.74 MB, 下载次数: 3)
板凳
发表于 2014-10-26 13:43:34 | 只看该作者
2楼观望。感谢楼主!
沙发
发表于 2014-10-14 20:57:36 | 只看该作者
沙花,谢谢楼主分享。。
GMT+8, 2026-9-28 10:47 , 耗时 0.108936 秒, 21 个查询请求 , Gzip 开启.
