查看: 4768|回复: 0
[ChipProg] DIP40/TSOP56 AE-TS56-16I
发表于 2015-7-4 12:12:37 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
DIP40/TSOP56 specialized adapter for FLASH memory
Description:
        DIP40/TSOP56 specialized adapter for FLASH memory. Device package dimensions: 14 x 20 mm, 0.5 mm pitch.
Supported Devices:
        Click the device programmer model below to get an appropriate list of the devices supported by this programmer with this adapter:
  • ChipProg-481
  • ChipProg-G41
  • ChipProg-48
  • ChipProg-40
        Adapter Connection Table:
DIP-40
TSOP-56
U1, 74AHC573
U2, 74AHC573
C1, 150pF
C2, 0.1uF
1
43
2
2
3
11
11
1
4
16
7
55
8
53
9
15
10
20
11
22
12
23
13
24
14
25
15
26
16
27
17
28
18
32
19
29
20
21,42,48
1, 10
1, 10
2
2
21
14
22
54
23
33
2
24
34
2
25
35
3
26
36
3
27
38
4
28
39
4
29
40
5
30
41
5
31
44
6
32
45
6
33
46
7
34
47
7
35
49
8
36
50
8
37
51
9
38
52
9
39
31
40
9.37
20
20
1
1
14
3
15
4
16
5
17
6
18
7
19
8
12
10
13
11
14
12
15
13
16
17
17
18
18
19
19
30
13
56
12
GMT+8, 2026-11-14 11:13 , 耗时 0.256672 秒, 22 个查询请求 , Gzip 开启.
