查看: 4705|回复: 0
[ChipProg] DIP40/TSOP56 AE-TS56-16I-4
发表于 2015-7-4 12:15:41 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
DIP40/TSOP56 specialized adapter for FLASH memory
Description:
        DIP40/TSOP56 specialized adapter for FLASH memory. Device package dimensions: 14 x 20 mm, 0.5 mm pitch.
Supported Devices:
        Click the device programmer model below to get an appropriate list of the devices supported by this programmer with this adapter:
  • ChipProg-481
  • ChipProg-G41
  • ChipProg-48
  • ChipProg-40
        Adapter Connection Table:
DIP-40
TSOP-56
U1, 74AHC573
U2, 74AHC573
C1, 150pF
C2, 0.1uF
1
38
2
3
11
11
1
4
44
5
27
6
28
7
14
8
56
9
43
10
19
11
20
12
21
13
22
14
23
15
24
16
25
17
29
18
13
19
20
12,31,45,46
1, 10
1, 10
2
2
21
30
22
32
23
34
2
24
35
2
25
36
3
26
37
3
27
39
4
28
40
4
29
41
5
30
42
5
31
47
6
32
48
6
33
49
7
34
50
7
35
51
8
36
52
8
37
53
9
38
54
9
39
40
33,15
20
20
1
10
14
11
15
16
16
17
17
18
18
55
19
1
12
2
13
3
14
4
15
5
16
6
17
7
18
8
19
9
13
26
12
GMT+8, 2026-11-14 11:11 , 耗时 0.152675 秒, 22 个查询请求 , Gzip 开启.
