查看: 19042|回复: 13
[资料] SPI Flash Microcontroller Programmer v3.7
发表于 2011-6-23 19:59:59 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
SPI Flash Microcontroller Programmer Ver 3.7
支持器件列表
at89sxx
at90sxx
atmegaxx
attinyxx
介绍
This SPI Flash Programmer can be used either for in-system programming or as a stand-alone serial flash programmer for the Atmel SPI programmable devices. The programmer hardware interface is controlled by the PC parallel port and the parallel port control signals are freely selectable by the user. The software supports both the 8051 and AVR series devices.
电路
Figure 1 shows  the  circuit diagram of the SPI Flash programmer hardware interface,  the  power to  the  interface  is provided either by a 9V dc adapter or a 9V battery. The 74HCT367 IC buffer the parallel port signals. It is necessary to use the HCT type IC in order to make sure the programmer should also work with the 3V type parallel port. The 74HCT04 is used to generate the clock signal for the u-controller when programming the device in stand-alone mode.
Figure 1:   Circuit Diagram of the SPI Flash Programmer
Figure 2  shows  the  connection diagram for the stand-alone programming, the u-controller to be program is placed  on  a  breadboard  or  on  a  veroboard  with a  ZIF socket, the required signals are then wired to the respective pins of the u-controller.
Figure 2:  Stand-alone SPI Programming interface
软件
The SpiPgm37.zip  file contains the main program and the io port driver. Place all files  in the same folder.
The main view of the program is shown in figure 3.
Also   make   sure   do   not   program    the    RSTDISBL    fuse   in   the AVR series devices, unless it is necessary  otherwise  further  serial  programming  is  disable, to  restore the serial programming a  high voltage parallel  programmer is required.
For  the  fuses setting consult the datasheet of  the respective u-controller.
Following are the main features of this software,
Read and write the BIN, HEX and ROM file formats Read Signature, Fuse and Lock bits Edit, Clear and Fill the Flash & Eeprom memory buffer Verify with memory buffer Auto save the OSCCAL data to Flash & Eeprom Display buffer checksum Program selected Fuse & Lock bits Auto save the fuses settings for the open program file Parallel port pins are freely selectable EEPROM file open and save commands
下载
SpiPgm37.zip (310.56 KB, 下载次数: 75)
Figure 3:   Main view of the program SPI-Pgm  Ver 3.7
收藏收藏1 分享分享 支持支持 反对反对
14#
发表于 2016-2-25 20:03:02 来自手机 | 只看该作者
Good job liyf
13#
发表于 2016-2-19 16:00:57 | 只看该作者
谢谢楼主分享
12#
发表于 2016-2-10 13:42:08 | 只看该作者
努力回帖!赚银两,赚积分!
11#
发表于 2015-11-4 08:13:44 | 只看该作者
努力回帖!赚银两,赚积分!
10#
发表于 2015-11-3 15:42:02 | 只看该作者
好好资料,多谢分享
9#
发表于 2015-1-2 23:33:24 | 只看该作者
好资料,感谢分享
8#
发表于 2014-7-10 11:16:25 | 只看该作者
这个真不错.ok
7#
 楼主| 发表于 2014-6-2 17:29:56 | 只看该作者
lhy83117 发表于 2014-6-2 16:30
spi专用机,要是做成一托4或一托8就会好很多。
这个spi是并口的,扩展有限
6#
发表于 2014-6-2 16:30:20 | 只看该作者
GMT+8, 2026-11-8 07:01 , 耗时 0.231181 秒, 21 个查询请求 , Gzip 开启.
