查看: 23510|回复: 20
pickit2编程器制作资料
发表于 2011-10-6 08:18:35 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Introduction
  PIC KIT2 is the high-speed programmer & Debugger designed specially for development programming of PIC single chip microcomputer. The product is featured with small volume, low power consumption, high reliability as well as easy and convenient operation.
  PIC KIT2 is applicable for almost all PIC10/12/16/18/24 and dspic30/33 FLASH series Microcontroller's Programming.
  PIC kit2 Development Programmer/Debugger" is a low-cost development tool with an easy to use interface for programming and debugging Microchip Flash families of microcontrollers.
  PIC kit2 is a USB based ICSP (In Circuit Serial Programming) programmer. Since its first release, Microchip has opened all resource of PIC kit2 to the public, which includes all software source code and hardware schematics.
Features
Features of PIC KIT2 Programmer:
1.High performance-price ratio, higher speed than other similar products, stable performance, support more devices. Support online upgrade of programmer hardware, easy and convenient upgrade. communication modes of USB port, convenient for application on lap-top computer which doesn’t have serial port .
2.Compatible with operating systems (OS) including Windows98, Windows2000/NT and Windows XP, Windows 2003, Windows Vista.
3.a RJ12 reverse cable is included, which makes it be able to work directly with circuit boards developed for ICD2.
4.Microchip-recommended schematic design.
5.Dimension: 58.5 x 30 x 6.5 mm.
6. ICSP interface: RJ12 6-Pin
7.Chip support: baseline (PIC10F, PIC12F5xx, PIC16F5xx), midrange (PIC12F6xx, PIC16F), PIC18F, PIC24, dsPIC30, dsPIC33, PIC32 and Microchip Serial EEPROM products.
8.with RJ12 6 pin reverse cable, pic kit2 can work directly with board developed for ICD2 for programming and debugging.
9.Additional power supply Input Port, The enhanced feature, "standalone power supply circuit", can provide regulated +5V power supply for PICkit 2 and application circuit. It is extremely useful for "Programmer-To-Go" feature.
  You can use Wall Mount DC 7V-10V 300mA-1000mA Power Supply - Positive Center, For example: 9V 500mA or 9V 1A
  You not need External power supply When you have connect USB to your pc.
PIC KIT2 PICKIT2 device support list.
PICkit 2 Programmer Application v2.61
Download PICkit 2 v2.61
  Device Programming SupportBold font indicates new devices in device file v1.62.9.
  MPLAB IDE v8.66
Download MPLAB IDE
Device Programming and Debugging SupportBold font indicates new devices in this version
 * Devices marked with an asterisk require a device specific ICD header board to enable debugging & the RJ-11 to ICSP Adapter.
Baseline Devices
  • PIC10F200, 202, 204, 206
  • PIC10F220, 222
  • PIC12F508, 509, 510, 519
  • PIC16F505, 506, 526
  • PIC16F54, 57, 59
Baseline – Programming & Debugging
  • PIC10F200*, 202*, 204*, 206*
  • PIC12F508*, 509*
  • PIC16F505*
    - Above use AC162059 ICD header & AC164110 adapter.
  • PIC10F220*, 222*
  • PIC12F510*
  • PIC16F506*
    - Above use AC162070 ICD header & AC164110 adapter.
Midrange Devices
‘LF’ versions of all devices are also supported
  • PIC12F609, HV609
  • PIC12F615, HV615
  • PIC12F617
  • PIC12F629, 635, 675, 683
  • PIC12F752
  • PIC16F610, HV610
  • PIC16F616, HV616
  • PIC16F627, 628
  • PIC16F627A, 628A, 648A
  • PIC16F630, 631, 636, 639, 676
  • PIC16F677, 684, 685, 687
  • PIC16F688, 689, 690
  • PIC16F707
  • PIC16F72
  • PIC16F73, 74, 76, 77
  • PIC16F720, 721
  • PIC16F722
  • PIC16F723, 724, 726, 727
  • PIC16F722A, 723A
  • PIC16F716
  • PIC16F737, 747, 767, 777
  • PIC16F785, HV785
  • PIC16F84A, 87, 88
  • PIC16F818, 819
  • PIC16F870, 871, 872
  • PIC16F873, 874, 876, 877
  • PIC16F873A, 874A, 876A, 877A
  • PIC16F882, 883, 884, 886, 887
  • PIC16F913, 914, 916, 917
  • PIC16F946
  • PIC16F1516, 1517, 1518, 1519
  • PIC16F1526, 1527
  • PIC16F1782, 1783
  • PIC12F1822
  • PIC16F1823, 1824
  • PIC16F1826, 1827, 1828
  • PIC16F1825, 1829
  • PIC12F1840
  • PIC16F1847
  • PIC16LF1902, 1903, 1904, 1906, 1907
  • PIC16F1933, 1934, 1936, 1937
  • PIC16F1938, 1939
  • PIC16F1946, 1947
Midrange – Programming & Debugging
  • PIC12F609*, HV609*
    - Use AC162083 ICD header & AC164110 adapter.
  • PIC12F615*, HV615*
  • PIC12F629*, 675*
    - Use AC162050 ICD header & AC164110 adapter.
  • PIC12F635*, PIC16F636*
    - Use AC162057 ICD header & AC164110 adapter.
  • PIC16F639*
    - Use AC162066 ICD header & AC164110 adapter.
  • PIC12F683*
    - Use AC162058 ICD header & AC164110 adapter.
  • PIC16F610*, HV610*
  • PIC16F616*, HV616*
  • PIC16F627A*, 628A*, 648A*
    - Use AC162053 ICD header & AC164110 adapter.
  • PIC16F630*, 676*
    - Use AC162052 ICD header & AC164110 adapter.
  • PIC16F684*
    - Use AC162055 ICD header & AC164110 adapter.
  • PIC16F688*
    - Use AC162056 ICD header & AC164110 adapter.
  • PIC16F631*, 677*, 685*, 687*, 689*, 690*
    - Use AC162061 ICD header & AC164110 adapter.
  • PIC16F716*
    - Use AC162054 ICD header & AC164110 adapter.
  • PIC16(L)F722, 723, 724, 726, 727
  • PIC16F785*, HV785*
    - Use AC162060 ICD header & AC164110 adapter.
  • PIC16F87, 88
  • PIC16F818, 819
  • PIC16F870, 871, 872, 873, 874, 876, 877
  • PIC16F946
PIC18F Devices
  • PIC18F242, 252, 442, 452
  • PIC18F248, 258, 448, 458
  • PIC18F1220, 1320, 2220, 2320
  • PIC18F1230, 1330
  • PIC18F2221, 2321
  • PIC18F2331, 2410, 2420, 2431
  • PIC18F2423
  • PIC18F2450, 2455, 2458, 2480
  • PIC18F2510, 2515, 2520, 2523
  • PIC18F2525
  • PIC18F2550, 2553, 2580, 2585
  • PIC18F2610, 2620, 2680
  • PIC18F2682, 2685
  • PIC18F4220, 4221
  • PIC18F4320, 4321, 4331
  • PIC18F4410, 4420, 4423
  • PIC18F4431, 4450, 4455
  • PIC18F4458, 4480
  • PIC18F4510, 4515, 4520, 4523
  • PIC18F4525, 4550, 4553, 4580
  • PIC18F4585
  • PIC18F4610, 4620, 4680
  • PIC18F4682, 4685
  • PIC18F6310, 6390, 6393
  • PIC18F6410, 6490, 6493
  • PIC18F6520, 6525, 6527, 6585
  • PIC18F6620, 6621, 6622, 6627
  • PIC18F6628, 6680
  • PIC18F6720, 6722, 6723
  • PIC18F8310, 8390, 8393
  • PIC18F8410, 8490, 8493
  • PIC18F8520, 8525, 8527, 8585
  • PIC18F8621, 8620, 8622, 8627
  • PIC18F8628, 8680
  • PIC18F8720, 8722, 8723
  • PIC18F24J10, F25J10, F44J10, F45J10
  • PIC18LF24J10, LF25J10, LF44J10, LF45J10
  • PIC18F24J11, F25J11, F44J11, F45J11
  • PIC18LF24J11, LF25J11, LF44J11, LF45J11
  • PIC18F26J11, F46J11
  • PIC18LF26J11, LF46J11
  • PIC18F24J50, F25J50, F44J50, F45J50
  • PIC18LF24J50, LF25J50, LF44J50, LF45J50
  • PIC18F26J50, F46J50
  • PIC18LF26J50, LF46J50
  • PIC18F63J11, 63J90, 64J11, 64J90
  • PIC18F65J10, 65J11, 65J15
  • PIC18F65J50, 65J90
  • PIC18F66J10, 66J11, 66J15, 66J16
  • PIC18F66J50, 66J55, 66J60, 66J65
  • PIC18F66J90
  • PIC18F67J10, 67J11, 67J50, 67J60
  • PIC18F67J90
  • PIC18F83J11, 83J90, 84J11, 84J90
  • PIC18F85J10, 85J11, 85J15, 85J50
  • PIC18F85J90
  • PIC18F86J10, 86J11, 86J15, 86J16
  • PIC18F86J50, 86J55, 86J60, 86J65
  • PIC18F86J90
  • PIC18F87J10, 87J11, 87J50, 87J60
  • PIC18F86J90
  • PIC18F96J60, 96J65
  • PIC18F97J60
  • PIC18F13K22, 14K22
  • PIC18F13K50, 14K50
  • PIC18F23K20, 24K20, 25K20, 26K20
  • PIC18F43K20, 44K20, 45K20, 46K20
  • PIC18F23K22, 24K22, 25K22, 26K22
  • PIC18F43K22, 44K22, 45K22, 46K22
PIC18F – Programming & Debugging
  • PIC18F1230, 1330
  • PIC18F2221, 2321
  • PIC18F2423,
  • PIC18F2525
  • PIC18F2682, 2685
  • PIC18F4220, 4221
  • PIC18F4458, 4480
  • PIC18F4585
  • PIC18F4682, 4685
  • PIC18F6628, 6680
  • PIC18F8628, 8680
  • PIC18F26J11, LF26J11, F46J11, LF46J11
  • PIC18F26J50, LF26J50, F46J50, LF46J50
  • PIC18F66J90
  • PIC18F67J90
  • PIC18F85J90
  • PIC18F86J90
  • PIC18F87J90
  • PIC18F97J60
  • PIC18F14K22
  • PIC18F24K20, 25K20, 26K20
  • PIC18F44K20, 45K20, 46K20
PIC24 Devices
  • PIC24F04KA200, 04KA201
  • PIC24F08KA101, 08KA102
  • PIC24F16KA101, 16KA102
  • PIC24FJ16GA002, 16GA004
  • PIC24FJ32GA002, 32GA004
  • PIC24FJ32GA102, 32GA104
  • PIC24FJ32GB002, 32GB004
  • PIC24FJ48GA002, 48GA004
  • PIC24FJ64GA002, 64GA004
  • PIC24FJ64GA102, 64GA104
  • PIC24FJ64GB002, 64GB004
  • PIC24FJ64GA006, 64GA008, 64GA010
  • PIC24FJ64GB106, 64GB108, 64GB110
  • PIC24FJ96GA006, 96GA008, 96GA010
  • PIC24FJ128GA006, 128GA008, 128GA010
  • PIC24FJ128GA106, 128GA108, 128GA110
  • PIC24FJ128GB106, 128GB108, 128GB110
  • PIC24FJ192GA106, 192GA108, 192GA110
  • PIC24FJ192GB106, 192GB108, 192GB110
  • PIC24FJ256GA106, 256GA108, 256GA110
  • PIC24FJ256GB106, 256GB108, 256GB110
  • PIC24HJ12GP201, 12GP202
  • PIC24HJ16GP304
  • PIC24HJ32GP202, 32GP204
  • PIC24HJ32GP302, 32GP304
  • PIC24HJ64GP202, 64GP204
  • PIC24HJ64GP206, 64GP210, 64GP506
  • PIC24HJ64GP502, 64GP504, 64GP510
  • PIC24HJ128GP202, 128GP204
  • PIC24HJ128GP206, 128GP210, 128GP306
  • PIC24HJ128GP310
  • PIC24HJ128GP502, 128GP504
  • PIC24HJ128GP506, 128GP510
  • PIC24HJ256GP206, 256GP210, 256GP610
PIC24 Devices
  • PIC24HJ16GP304
  • PIC24HJ128GP310
dsPIC30 Devices
  • dsPIC30F1010
  • dsPIC30F2010, 2011, 2012
  • dsPIC30F2020, 2023
  • dsPIC30F 3010, 3011, 3012
  • dsPIC30F3013, 3014
  • dsPIC30F4011, 4012, 4013
  • dsPIC30F5011, 5013, 5015, 5016
  • dsPIC30F6010A, 6011A, 6012A
  • dsPIC39F6013A, 6014A, 6015
dsPIC30 Devices
  • dsPIC30F1010
dsPIC33 Devices
  • dsPIC33FJ12GP201, 12GP202
  • dsPIC33FJ16GP304
  • dsPIC33FJ32GP202, 32GP204
  • dsPIC33FJ32GP302, 32GP304
  • dsPIC33FJ64GP202, 64GP204
  • dsPIC33FJ64GP206, 64GP306, 64GP310
  • dsPIC33FJ64GP206A, 64GP306A, 64GP310A
  • dsPIC33FJ64GP706, 64GP708, 64GP710
  • dsPIC33FJ64GP706A, 64GP710A
  • dsPIC33FJ64GP802, 64GP804
  • dsPIC33FJ128GP202, 128GP204
  • dsPIC33FJ128GP206, 128GP306, 128GP310
  • dsPIC33FJ128GP206A, 128GP306A, 128GP310A
  • dsPIC33FJ128GP706, 128GP708, 128GP710
  • dsPIC33FJ128GP706A, 128GP710A
  • dsPIC33FJ128GP802, 128GP804
  • dsPIC33FJ256GP506, 256GP510, 256GP710
  • dsPIC33FJ256GP506A, 256GP510A, 256GP710A
  • dsPIC33FJ06GS101, 06GS102, 06GS202
  • dsPIC33FJ16GS402, 16GS404
  • dsPIC33FJ16GS502, 16GS504
  • dsPIC33FJ12MC201, 12MC202
  • dsPIC33FJ16MC304
  • dsPIC33FJ32MC202, 32MC204
  • dsPIC33FJ32MC302, 32MC304
  • dsPIC33FJ64MC202, 64MC204
  • dsPIC33FJ64MC506, 64MC508, 64MC510
  • dsPIC33FJ64MC706, 64MC710
  • dsPIC33FJ64MC802, 64MC804
  • dsPIC33FJ128MC202, 128MC204
  • dsPIC33FJ128MC506, 128MC510
  • dsPIC33FJ128MC706, 128MC708, 128MC710
  • dsPIC33FJ128MC802, 128MC804
  • dsPIC33FJ256MC510, 256MC710
dsPIC33 Devices
  • dsPIC33FJ16GP304
  • dsPIC33FJ16MC304
PIC32 Devices
  • PIC32MX320F032H, 320F064H
  • PIC32MX320F128H, 320F128L
  • PIC32MX340F128H, 340F128L
  • PIC32MX340F256H
  • PIC32MX340F512H
  • PIC32MX360F256L, 360F512L
  • PIC32MX420F032H
  • PIC32MX440F128L, 440F128H
  • PIC32MX440F256H
  • PIC32MX440F512H
  • PIC32MX460F256L, 460F512L
以下这些支持是需要改变一下对应脚的,爷爷就是说要用适配器
KEELOQ HCS Devices
HCS200     HCS201     HCS300     HCS301      HCS320
HCS360     HCS361     HCS362
HCSxxx File -> Import HEx Notes:
The first line only may be imported from SQTP
                *.NUM files generated by the KEELOQ tool in
                MPLAB.
        Connections for HCS devices
        PICkit 2 Pin             HCS Device Pin
        (2) Vdd                  8
        (3) GND                  5
        (5) PGC                 /3            HCS20x, 320
                                \3 -or- 4     HCS30x, 36x
        (4) PGD                  6
        (1) VPP                  2            HCS360, 361 only
MCP250xx CAN Devices
MCP25020*      MCP25025*
MCP25050*      MCP25055*
!!IMPORTANT!! - MCP250xx devices are OTP and can only be
                programmed once.
        Connections for MCP250xx devices
        PICkit 2 Pin             MCP Device Pin (DIP)
(1) Vpp                  11 Vpp
        (2) Vdd                  14 VDD
- The MCP device MUST be powered from PICkit 2!
        (3) GND                  7 Vss
        (4) PGD                  5 DATA
        (5) PGC                  6 CLOCK
Serial EEPROM Devices
NOTE: Other supported voltage grades are listed in parentheses
      next to the device.  Select the "LC" part number to program
      these other voltage grades.
11LC010 (AA)*
11LC020 (AA)*
11LC040 (AA)*
11LC080 (AA)*
11LC160 (AA)*
24LC00   (AA)(C)                  25LC010A (AA)
24LC01B  (AA)                     25LC020A (AA)
24LC02B  (AA)                     25LC040A (AA)
24LC04B  (AA)                     25LC080A (AA)
24LC08B  (AA)                     25LC080B (AA)
24LC16B  (AA)                     25LC160A (AA)
24LC32A  (AA)                     25LC160B (AA)
24LC64   (AA)(FC)                 25LC320A (AA)
24LC128  (AA)(FC)                 25LC640A (AA)*
24LC256  (AA)(FC)                 25LC128  (AA)
24LC512  (AA)(FC)                 25LC256  (AA)
24LC1025 (AA)(FC)                 25LC512  (AA)
                                             25LC1024 (AA)
93LC46A/B/C  (AA)(-C)
93LC56A/B/C  (AA)(-C)
93LC66A/B/C  (AA)(-C)
93LC76A/B/C  (AA)(-C)
93LC86A/B/C  (AA)(-C)
        Connections for 11LC devices
        PICkit 2 Pin             11LC Device Pin (DIP)
        (2) Vdd !                8 Vcc
        (3) GND                  4 Vss
        (6) AUX                  5 SCIO
! 11LC devices may not program properly below 3.6V VDD.
          This is a limitation of the PICkit 2 AUX IO pin.
        Connections for 24LC devices
        PICkit 2 Pin             24LC Device Pin (DIP)
        (2) Vdd !                8 Vcc
        (3) GND                  4 Vss
        (5) PGC                  6 SCL (driven as push-pull)
        (6) AUX                  5 SDA (requires pullup)
                                 7 WP - disabled (GND)
                                 1, 2, 3 Ax pins
                                    Connect to Vdd or GND per
                                    datasheet and to set address
! 24LC devices may not program properly below 3.6V VDD.
        Connections for 25LC devices
        PICkit 2 Pin             25LC Device Pin (DIP)
        (1) VPP                  1 nCS
        (2) Vdd                  8 Vcc
        (3) GND                  4 Vss
        (4) PGD                  2 SO
        (5) PGC                  6 SCK
        (6) AUX                  5 SI
                                 7 nHOLD - disabled (Vdd)
                                 3 nWP - disabled (Vdd)
        Connections for 93LC devices
        PICkit 2 Pin             93LC Device Pin (DIP)
        (1) VPP                  1 CS
        (2) Vdd                  8 Vcc
        (3) GND                  5 Vss
        (4) PGD                  4 DO
        (5) PGC                  2 CLK
        (6) AUX                  3 DI
                                 7 PE - enabled (Vdd)
                                 6 'C' Device ORG
                                    Set to select word size
编程器原理图(在用户手册中51、52页)
第一部分
第二部分
pickit2 v2.50.02软件
PICkit 2 v2.50.02 Setup A.rar (3.77 MB, 下载次数: 3002)
用户手册
PICkit2_USER_GUIDE.pdf (1.05 MB, 下载次数: 132)
命令行工具,这个一般用的少,一起上传了
PK2CMDv1-01b.rar (47.81 KB, 下载次数: 28)
v2.31固件
PK2V023001.rar (22.99 KB, 下载次数: 31)
脱机操作手册
Programmer-To-Go_User_Guide.pdf (457.99 KB, 下载次数: 36)
当然都是英文的哦
收藏收藏2 分享分享 支持支持 反对反对
19#
发表于 2021-2-9 16:06:39 | 只看该作者
谢谢分享,学习了。
18#
发表于 2020-6-1 00:05:02 | 只看该作者
谢谢分享  下载了 居然安装不了  不知咋回事
17#
发表于 2016-5-30 00:33:50 | 只看该作者
PIC用的多吗?
15#
发表于 2013-12-24 10:49:55 | 只看该作者
先下来看看
14#
发表于 2013-12-23 22:43:05 | 只看该作者
先谢谢了.没银子下不了了
13#
发表于 2013-12-11 10:31:07 | 只看该作者
好资料,收藏了,
12#
发表于 2013-12-9 12:20:53 | 只看该作者
收藏一份,感谢分享。
11#
发表于 2013-9-13 09:54:55 | 只看该作者
GMT+8, 2026-8-16 17:13 , 耗时 0.193429 秒, 24 个查询请求 , Gzip 开启.
