查看: 5752|回复: 0
Olimex PIC-PG3 Programmer
发表于 2012-2-27 18:05:07 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
Description
PIC-PG3 is programmer based on D.Tait's parallel port design. To operate it needs external power supply 12-15VAC or 16-18VDC. It supports all 8/18/28 and 40 pin PIC microcontrollers which allow serial programming. PIC-PG3 have connector and cable for ICSP programming and can be used to program all PIC-PxxB prototype boards. You can get a fully assembled and tested PIC-PG3 programmer at http://www.olimex.com.
Important note:
For this programmer the programmer autodetection feature has to be deactivated (Menu: Hardware - Hardware Selection/Configuration...) by directly selecting the Olimex PIC-PG3 programmer. Reason for this is that this programmer has overlapping MCLR pins depending on the IC sockets which could cause Vpp on a PIC port pin different than MCLR pin. Due to that also the corresponding Olimex PIC-PG3 programmer type has to be selected. I.e. if you want to program a 8, 14 or 18 pin PIC, you have to select the "Olimex PIC-PG3 (8pin, 14pin, 18pin)" programmer. To program a 28 or 40 pin PIC you have to select "Olimex PIC-PG3 (28pin, 40pin)".
Schematics / Layouts
http://www.olimex.com/dev/pic-pg3.html
Pictures, Further Notes
To program a 8, 14 or 18 pin PIC, you have to select the "Olimex PIC-PG3 (8pin, 14pin, 18pin)" programmer in the Hardware settings.
To program a 28 or 40 pin PIC, you have to select the "Olimex PIC-PG3 (28pin, 40pin)" programmer in the Hardware settings.
GMT+8, 2026-11-8 05:34 , 耗时 1.754747 秒, 25 个查询请求 , Gzip 开启.
