查看: 7409|回复: 3
[河洛HILO] ADP-MACH1 AMD MACH130 / MACH230 / MACH435 (84 PINs PLCC)
发表于 2013-9-7 10:29:37 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
84 Pin PLCC SocketSignal NameDIP40 of the ALL03 / ALL07Comments
1GND20
2VCC9
310K Pulldown R-
410K Pulldown R-
510K Pulldown R-
610K Pulldown R-
710K Pulldown R-
810K Pulldown R-
910K Pulldown R-
10SI/O725
11GND20
12SI/O826
1310K Pulldown R-
1410K Pulldown R-
1510K Pulldown R-
1610K Pulldown R-
1710K Pulldown R-
1810K Pulldown R-
19SI/O151
20CLK1pin 4 IC 74LS14
21VCC9
22GND20
23VPPcenter pin SW1-2if MACH1 shorted to 13 if MACH435 shorted to 37
24SI/O162
25SI/O175
2610K Pulldown R-
2710K Pulldown R-
2810K Pulldown R-
2910K Pulldown R-
3010K Pulldown R-
31SI/O2327
32GND20
33SI/O2428(corrected)
34SI/O2524(corrected)
3510K Pulldown R-
3610K Pulldown R-
3710K Pulldown R-
38SEC19
3910K Pulldown R-
4010K Pulldown R-
41ENABLEcenter pin Switch SW1-1if MACH1 shorted to 37 if MACH435 shorted to 13
42VCC9
43GND20
44VCC9
4510K Pulldown R-
4610K Pulldown R-
4710K Pulldown R-
4810K Pulldown R-
4910K Pulldown R-
5010K Pulldown R-
5110K Pulldown R-
52SI/O3929
53GND20
54SI/O4030
5510K Pulldown R-
5610K Pulldown R-
5710K Pulldown R-
5810K Pulldown R-
5910K Pulldown R-
6010K Pulldown R-
61SI/O473
62CLK234
63VCC9
64GND20
65MD117
66SI/O484
6710K Pulldown R-
6810K Pulldown R-
6910K Pulldown R-
7010K Pulldown R-
7110K Pulldown R-
7210K Pulldown R-
73SI/O5531
74GND20
75SI/O5632
7610K Pulldown R-
7710K Pulldown R-
7810K Pulldown R-
7810K Pulldown R-
7910K Pulldown R-
8010K Pulldown R-
8110K Pulldown R-
8210K Pulldown R-
83MD218
84VCC9
10nF cap. between
pin 13 and pin 20
pin 1 IC 74LS14
33
pin 2,3 IC 74LS14 shorted together
pin 4 IC 74LS1420
pin 7 IC 74LS14
20
pin 14 IC 74LS14
7
100 nF cap. between pin 14, 7 IC 74LS14
100nF cap. between 1,2 ; 21,22 ; 42,43 ; 63,64
100 nF cap.
between pin 9,20
10 uF/25V tantale
between pin 9 (+) and pin 20 (-)
adp-mach1.pdf (24.62 KB, 下载次数: 13)
地板
发表于 2020-6-20 06:20:29 | 只看该作者
谢谢分享皮底爱抚资料。
板凳
发表于 2019-12-10 07:15:31 | 只看该作者
do you have gerber
沙发
发表于 2019-12-10 06:59:12 | 只看该作者
hello, very good thansk
GMT+8, 2026-11-14 11:11 , 耗时 0.116337 秒, 21 个查询请求 , Gzip 开启.
