查看: 8344|回复: 1
开源的usb pic programmer
发表于 2011-5-4 13:50:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The hardware is built around a microchip PIC18F2550, this microcontroller has on board USB capabilities. The schematic and PCB have been designed in Kicad, an open source EDA solution
The PCB files are available in Gerber format and the schematic in pdf in the download section so that you can open them with your favourite tool.
The interface to the target PIC processor uses TTL levels (0 and 5 volts) which limits the hardware to the PIC10, PIC12, PIC16, PIC17, PIC18 and dsPIC30 series of processors. The hardware (from version 0.3) is capable of creating levels for PIC24 / PIC33 / PIC18FXXJXX devices as well.
硬件电路部分
usbpicprog-hardware-0.3.2[1].zip (782.92 KB, 下载次数: 39)
固件
firmware-0.4.2-beta.tar.gz (174.79 KB, 下载次数: 32)
软件
UsbPicProg-x86-0.4.2-beta.part1.rar (7.63 MB, 下载次数: 95)
UsbPicProg-x86-0.4.2-beta.part2.rar (1.23 MB, 下载次数: 32)
最新软件可以到这里下
http://sourceforge.net/projects/usbpicprog/files/usbpicprog-software/
沙发
发表于 2022-8-16 03:33:53 | 只看该作者
来晚了,估计没银子了。那也顶一贴!
GMT+8, 2026-11-8 14:39 , 耗时 0.693548 秒, 20 个查询请求 , Gzip 开启.
